Sizing, shaping, and rotating vector objects
You can transform vector objects and vector text interactively. For example, you can drag the handles on a bounding box to size, shape, or rotate objects. You can also transform vector objects by editing their nodes. For more information, see Working with nodes.
You can also size vector object to make them the same width, height, or both.
To size and shape a vector object |
Edit workspace
1 |
On the Tools toolbar, choose the Pick tool .
2 |
Select the object.
3 |
Perform any of the steps in the following table.
To rotate vector objects |
Edit workspace
1 |
2 |
Select an object.
3 |
Drag the rotation handle.
To change the center of rotation, hold down Ctrl, and drag the
rotation pivot point to a new location.
To make vector objects the same size |
Edit workspace
1 |
2 |
Select the first vector object.
The first object controls how all the other vector objects are resized. |
3 |
Hold down Shift, and click the other objects you want to resize.
4 |
On the Tool Options palette, choose one of the following options
from the Same Size group box:
Make Same Height
Make Same Width
Make Same Width and Height
To change the object’s proportions while resizing, select the
object with the Pick tool , and then right-click and drag a
corner handle.
