Using anti-aliasing with selections
Anti-aliasing produces a smooth-edged selection by partially filling in pixels along the edge, making them semitransparent. You can apply anti-aliasing to selections as you create them. For more information about creating selections, see Creating selections.
After a selection is created, you can apply anti-aliasing based on the selection’s shape. You can also restore the original anti-aliasing of an object that was pasted into an image. Restoring anti-aliasing is useful if you made the selection without anti-aliasing and you want to smooth the edges of the selection.
| To apply anti-aliasing based on shape |
Edit workspace
1 |
Choose Selections |
The Shape Based Anti-alias dialog box appears. |
2 |
Mark one of the following options:
Inside — applies anti-aliasing to the inside of the selection
marquee
Outside — applies anti-aliasing to outside of the selection
marquee
3 |
Click OK.
The selection edges are anti-aliased. |
| To recover anti-aliasing |
Edit workspace
1 |
Choose Selections |
The Recover Anti-alias dialog box appears, with the anti-aliased selection displayed in the After preview area. |
2 |
Inside — applies anti-aliasing inside the selection marquee
Outside — applies anti-aliasing outside the selection marquee
3 |
Click OK.
To apply anti-aliasing to all layers in the selection, mark the Use
all layers check box.
To apply anti-aliasing and copy the result to a new layer, mark
the Result on new layer check box.
