Using layer styles
You can apply a variety of effects, either alone or in combination, by using the Layer Styles tabbed area of the Layer Properties dialog box. With this feature, you can create visually interesting and creative effects to a layer in real time, and you can fine-tune the effect before applying it. The Layer Styles feature provides six effects: Reflection, Outer Glow, Bevel, Emboss, Inner Glow, and Drop Shadow.
When you apply these effects on a separate layer and save the resulting file in a layer-capable file format (such as the PspImage format), your original image remains unedited on its own layer. In this sense, layer styles are similar to adjustment layers. They differ, however, in that layer styles are applied not to the underlying canvas, but just to the boundaries of the individual layer.
If you resize a layer with one or more layer styles applied to it, the effects are resized proportionally.
Layer styles can be applied only to raster and vector layers.
Some layer styles (such as Drop Shadow) are applied outside the layer’s data. Some layer styles won’t be seen unless the layer includes areas of transparency.
Why is there a “Layer” check box?
When marked, this check box lets you show the layer data with the effects applied. When unmarked, this check box lets you turn off the layer data and just show the effects. Unmarking the Layer check box makes the original layer data behave as if a mask were applied to it.
Is there a reason for the check box order?
Yes. The effects need to be composited in a particular order to obtain sensible results. For example, you would not want a Drop Shadow effect placed on top of its source object, nor would you want an Outer Glow effect placed under a Drop Shadow effect. Thus, the Reflection effect is placed on top, followed by the Outer Glow effect, the Bevel effect, and so on. The Drop Shadow effect is applied last.
What happens when I edit layers with effects?
Whether you edit a vector layer by adding new text or shapes, or edit a raster layer by painting with a brush tool, the effects previously applied to the layer are applied to any modifications you make.
Layers Styles examples
For more information on using Layer Styles, refer to the Help.
| To apply a Reflection layer style |
Edit workspace
1 |
Double-click the layer on which you want to apply the effect.
2 |
In the Layer Properties dialog box, click the Layer Styles tab.
3 |
In the group box that lists the effects, mark the Reflection check
box.
The After pane is updated to show the initial Reflection effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
The Reflection effect may create data that extends beyond the viewable image canvas, so you may need to expand the canvas to see the entire effect. |
4 |
Drag the Size slider to set the speed with which the reflection
fades in comparison with the original layer data.
5 |
Drag the Opacity slider to set the intensity of the reflection’s
overall lightness.
6 |
Drag the red Reflection Distance control line to set the horizontal
axis about which all layer data is reflected.
7 |
Click OK.
You can save Layer Styles settings as a preset and then apply
them at any time to another layer. For more information on
saving and applying presets, see Using and creating presets.
| To apply an Outer Glow layer style |
Edit workspace
1 |
2 |
3 |
In the group box that lists the effects, mark the Outer Glow check
box.
The After pane is updated to show the initial Outer Glow effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
The Outer Glow effect may create data that extends beyond the viewable image canvas, so you may need to expand the canvas to see the entire effect. |
4 |
Drag the Size slider to set how far the glow extends outside the
layer data.
5 |
Drag the Opacity slider to set the lightness intensity and visibility
of the glow.
6 |
In the rainbow color picker, click a glow color. The current color
appears along the bottom row of the color picker.
7 |
Click OK.
| To apply a Bevel layer style |
Edit workspace
1 |
2 |
3 |
In the group box that lists the effects, mark the Bevel check box.
The After pane is updated to show the initial Bevel effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
4 |
Drag the Size slider to set the distance from the outer edge of the
layer data to the extent of the bevel.
5 |
Drag the Opacity slider to set lightness intensity and visibility of
the bevel.
6 |
Drag the two-dimensional lighting control |
7 |
In the rainbow color picker, click a bevel color. The current color
8 |
Click OK.
| To apply an Emboss layer style |
Edit workspace
1 |
2 |
3 |
In the group box that lists the effects, mark the Emboss check box.
The After pane is updated to show the initial Emboss effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
4 |
layer data to the extent of the embossing.
5 |
the embossing.
6 |
7 |
Click OK.
| To apply an Inner Glow layer style |
Edit workspace
1 |
2 |
3 |
In the group box that lists the effects, mark the Inner Glow check
box.
The After pane is updated to show the initial Inner Glow effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
4 |
Drag the Size slider to set how far glow extends inside the layer
data.
5 |
of the glow.
6 |
7 |
Click OK.
| To apply a Drop Shadow layer style |
Edit workspace
1 |
2 |
3 |
In the group box that lists the effects, mark the Drop Shadow
check box.
The After pane is updated to show the initial Drop Shadow effect. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
The Drop Shadow effect may create data that extends beyond the viewable image canvas (particularly on a layer the same size as the Background layer), so you may need to expand the canvas to see the entire effect. |
4 |
Drag the Size slider to set the distance between the layer data and
the shadow.
As you increase the size, the shadow becomes more blurred. |
5 |
the shadow.
6 |
7 |
In the rainbow color picker, click a shadow color. The current color
8 |
Click OK.
| To adjust the layer data visibility |
Edit workspace
1 |
Double-click the layer on which you want to modify the visibility of
the layer data.
When you modify the visibility of layer data, you are not changing the visibility of the effects applied to the layer. |
2 |
3 |
In the group box that lists the effects, mark the Layer check box.
The After pane is updated to show the effect of marking the box. If you want to preview the changes on the actual image, mark the Preview on Image check box. |
Drag the Opacity slider to set the light intensity and visibility of the layer data. |
4 |
To turn off layer data visibility, unmark the Layers check box.
5 |
Click OK.
| To display or hide layer effects |
Edit workspace
1 |
On the Layers palette, click a layer that has effects applied.
2 |
Click the Layer Effects Visibility Toggle button |
A layer effect icon |
