Viewing images
You can view images in a tabbed format, in which a tab appears at the top of the image window. When you click a tab, the image in that window becomes the active image. You can also view images in windows, which you can move, resize, or close. You can open the same image in multiple tabs or image windows, which lets you see the image at different magnification levels.
If you have multiple images open, you can arrange the image windows to view them side by side or stacked in cascading order. You can also see a list of all open images.
If the image is larger than the image window, you can pan to view different parts of the image, or you can fit the window to the image. You can also see a thumbnail of the entire image in the Overview palette. For more information, see Using palettes.
The title bar at the top of the image window shows the filename and the magnification percentage. An asterisk after the filename indicates that the image has been modified and that those changes have not been saved.
If the image has an embedded watermark, a copyright symbol is displayed in front of its name. For more information, see Using digital watermarks.
| To enable or disable the tabbed image window option |
Edit workspace
Choose Window |
To view another image, click its tab. If an image tab is not in the
current view, click the arrows in the upper-right corner of the
image window to scroll left or right.
To close a tabbed-format image, click the Close button |
| To move an image window |
Edit workspace
Drag the title bar.
| To resize an image window |
Edit workspace
Drag a corner of the image window.
When you resize an image window, you are not changing the
size of the image.
| To minimize or maximize an image window |
Edit workspace
Perform a task from the following table.
| To close an image window |
Edit workspace
Choose File |
If you have made unsaved changes to your image, you are prompted to save. |
You can also click the Close button |
To close all windows, choose Window |
| To make a copy of the active image |
Edit workspace
Choose Window |
A copy of the active image opens. You can edit the copy independently of the original image. |
You can also duplicate the active image by pressing Shift + D.
| To open multiple views of the same image |
Edit workspace
Choose Window |
A new window opens with another view of the active image. When you make changes in one window, both windows are updated. |
| To arrange multiple windows |
Edit workspace
| To see a list of all open images |
Edit workspace
Click the Window menu.
The names of all open images appear at the bottom of the Window menu. The filenames are listed in the order in which they were opened. |
| To view another area of the image |
Edit workspace
| To fit the image in the image window |
Edit workspace
