Add drop shadows and inner shadows
Drop shadows and inner shadows simulate light falling on objects, adding 3D depth for a more realistic appearance. Drop shadows appear behind or below objects; inner shadows appear inside objects.
You can add drop shadows and inner shadows to most objects or groups of objects, including text and bitmaps.
You can add drop shadows and inner shadows interactively or by using presets. After you add a shadow, you can edit it. For example, you can adjust attributes such as color, opacity, offset, and feathering. You can edit shadows interactively by using the vector control or by using controls on the property bar.
A drop shadow applied to an object. The feathered effect softens the edges of the drop shadow on the right.
An inner shadow applied to an object
By changing the settings of the inner shadow, you can change the object appearance. The same text object with different inner shadow settings.
After you create a shadow, you can copy it or clone it to a selected object. When you copy a shadow, the original and copy have no connection and can be edited independently. With cloning, the master object’s shadow attributes are automatically applied to its clone.
By separating a shadow from its object, you gain more control over the shadow itself. For example, you can edit the shadow as you would edit a transparency.In addition, you can separate a shadow from its object so that you can apply both an inner shadow and a drop shadow to an object.
As with transparencies, you can apply a merge mode to a shadow to control how the color of the shadow blends with the color of the object underneath. For more information about merge modes, see Merge modes.
You can remove drop shadows and inner shadows.
Drop shadows and extrusions created in CorelDRAW are ideal for printed outputs, but are not appropriate for output to devices such as vinyl cutters and plotters. Cuttable shadows are needed for such projects. To add a cuttable shadow to an object, you must use a block shadow. For more information about block shadows, see Add block shadows.
You can also create a cuttable shadow by duplicating the object, filling the duplicate with a dark color, and then placing it behind the original object.
You can also use extrusions to create shadows.
To add a drop shadow or an inner shadow
Back to Top
1 In the toolbox, click the Shadow tool .
2 Perform a task from the following table.
To
Do the following
Add a drop shadow
On the property bar, click the Drop shadow tool . Drag from the center of the object to position the drop shadow.
To add a perspective drop shadow, drag from the object edge.
A flat drop shadow (left), and a perspective drop shadow (right)
Add an inner shadow
On the property bar, click the Inner shadow tool . Drag from the center of the object until the inner shadow is the size you want. The closer to the edge you drag the end handle, the narrower the inner shadow becomes.
Tip: To offset the inner shadow, drag beyond the edges and the bounding box of the object.
Shadows cannot be added to linked groups, such as blended objects, contoured objects, beveled objects, extruded objects, objects created with the Artistic media tool , or other shadows.
You cannot add shadows to a bitmap which has been shaped by an envelope or to objects that have bitmap effects applied to them.
You can apply only one shadow to an object — a drop shadow or an inner shadow, not both. However, you can use grouping to apply both shadows to the same object. For example, you can apply an inner shadow to an object, create a group from that object, and then apply a drop shadow to the group.
You can also add a shadow by choosing a preset from the Preset list box on the property bar.
Top: Different drop shadow presets applied to an object. Bottom: Different inner shadow presets applied to an object.
To edit a drop shadow or an inner shadow
Back to Top
2 Click an object with a shadow.
3 Use any of the following controls on the property bar to specify the shadow attributes:
Shadow color — to choose the shadow color
Merge mode — to choose how the color of the shadow blends with the color of the underlying object. The default merge mode Multiply produces natural-looking shadows.
Shadow opacity — to adjust the transparency of the shadow
Shadow feathering — to sharpen or soften the edges of the shadow
Feathering direction — to soften the shadow’s edges towards the inside of the shadow, the outside of the shadow, or in both directions. Shadows look more realistic when they use Gaussian Blur feathering, which is the default option. The Inside and Average options are not available for inner shadows.
Feather edge — to choose a feathering type. This control is not available for Gaussian Blur feathering.
Inner shadow width — to set the width of an inner shadow that is not offset
Shadow offset — to change the distance between shadow and the object edge. With drop shadows, changing the offset makes the object appear closer or further away from the background.
You can also
Edit a perspective drop shadow
Use any of the following controls:
Shadow angle — to set the direction of the drop shadow
Shadow stretch — to set the length of the drop shadow
Shadow fade — to adjust the fading of the drop shadow
Note: These controls are not available for inner shadows and flat drop shadows.
Perspective drop shadows with different angle, stretch and fade values
Save the custom settings as a preset
Click the Add preset button , and type a name for the shadow preset.
Shadow presets are saved to your Documents/Corel/Corel Content/CorelDRAW/Presets/Shadow folder.
Delete a custom shadow preset
Choose a custom preset from the Preset list box, and click the Delete preset .
To copy or clone a drop shadow or an inner shadow
Back to Top
1 Select the object to which you want to copy or clone a shadow.
To
Do the following
Copy a drop shadow
Click Object Copy Effect Shadow From, and click the drop shadow of an object.
Copy an inner shadow
Click Object Copy Effect Shadow From, and click the inner shadow of an object.
Clone a drop shadow
Click Object Clone Effect Shadow From, and click the drop shadow of an object.
Clone an inner shadow
Click Object Clone Effect Shadow From, and click the inner shadow of an object.
You can also use the Attributes eyedropper tool to copy a drop shadow or an inner shadow. For more information, see To copy effects from one object to another.
You can also copy a shadow from one object to another by using the Copy shadow properties button on the property bar.
To separate a drop shadow or inner shadow from an object
Back to Top
1 Using the Pick tool , select an object’s drop shadow or inner shadow.
2 Do one of the following:
Click Object Break Drop Shadow Apart.
Click Object Break Inner Shadow Apart.
3 Click a blank space in the drawing window to deselect the object and the shadow, and then drag the shadow.
Separating an inner shadow from an object
You can use this procedure to apply both an inner shadow and a drop shadow to an object. For example, you can apply a drop shadow to an object, break the drop shadow apart, and then apply an inner shadow to the object.
To remove a drop shadow or an inner shadow
Back to Top
1 Select an object’s shadow.
2 Click Object Clear Shadow.
You can also remove a shadow from an object by selecting the shadow and clicking Clear Shadow on the property bar.
