Corel periodically releases Microsoft patch (MSP) files — also known as "patches" or "updates" — for its products. Installing updates helps keep the software up-to-date.
In this guide, Patch.exe is a placeholder for the filename of the update. The actual filename varies with each update.
Many network administrators keep their software up-to-date by monitoring the Corel Support Services website (www.corel.com/support). When an update is made available, these administrators download it and carry out the patching process themselves.
In this guide, \\server\path\Patch.exe is a placeholder for the location and filename of the downloaded patch.
If you prefer to have workstation users patch the software for themselves, you can set up the server image to enable the automatic detection of available patches. For details, see Setting up the server image.
After locating and downloading an update, you can apply it to the server image and then use the updated image to patch the installed software.
You can apply an update to the server image. You must begin by extracting the patch files to a specified location.
After extracting the patch, be sure to apply all extracted patch files to the server image. Applying only some of the patch files may cause the installations to function incorrectly.
After updating the server image, you can deploy the update to the workstations.
By default, the REINSTALLMODE=oums property is applied. For best results, you may want to specify REINSTALLMODE=vdm:
For details on REINSTALL (and REINSTALLMODE), see REINSTALL and REINSTALLMODE.
