The software must be configured and deployed on workstations using the following procedure. All users of the software need access to the installation location.
It is essential that you deploy the Corporate_CDGS_[Intel or Silicon].pkg file before deploying the CorelDRAW Graphics Suite.pkg file.
If you use Terminal to deploy the files, make sure Terminal has access to the folder where the required files are located. In System Preferences, click Security & Privacy. In the Security & Privacy dialog box, click the Privacy tab, and choose Files and Folders in the left pane. In the right pane, scroll to Terminal, and enable the check box for the folder where the files are located.
If you can’t deploy the software, make sure that:
The default deployment options allow users to save files to Corel Cloud by signing in with a Corel user account. Using the CDAEnterpriseAccess key, you can give users access to Corel Cloud through SSO after the suite was deployed to the workstations.
During installation, the CDAEnterpriseAccess key is added to registry.xml in /Library/Corel/CorelDRAW Graphics Suite 2025/CommonData/Registry. By default, access to Corel Cloud through SSO is restricted so the value is set to "0":
To enable access to Corel Cloud through SSO, you must change the data value in registry.xml from "0" to "Enable":
