The colors of the images that you work with in CorelDRAW are based on color modes. Color modes define the color characteristics of images and are described by their component colors. The CMYK color mode is composed of cyan, magenta, yellow, and black values; the RGB color mode is composed of red, green, and blue values.
Although you may not be able to see the difference between an image in the CMYK color mode and an image in the RGB color mode on screen, the images are quite different. For the same image dimensions, an RGB image has a smaller file size than a CMYK image and the RGB color space, or gamut, can display more colors. Therefore, images intended for the Web or desktop printers, which require accurate color fidelity, are generally in RGB mode. Where accurate print reproduction is needed, such as on a commercial printing press, images are generally created in CMYK mode. Paletted color images attempt to preserve color fidelity while reducing the file size, making them ideal for on-screen uses.
Each time you convert an image, you may lose color information. For this reason, you should save an edited image before you change it to a different color mode. For more information about color modes, see Working with color.
CorelDRAW supports the following color modes:
Black and White (1-bit)
Duotone (8-bit)
Grayscale (8-bit)
Paletted (8-bit)
RGB Color (24-bit)
Lab Color (24-bit)
CMYK Color (32-bit)
To change the color mode of a bitmap |
1 |
Click a bitmap.
2 |
Click Bitmaps Mode, and click a color mode.
The current mode of the selected bitmap is not available in the menu.
