You can specify color management options for exporting files to PDF. You can choose a color profile or leave the objects in their original color space. You can also embed the color profile with the PDF.
If you have spot colors in your file, you can either preserve the spot colors or convert them to process colors so that the file produces four plates for CMYK output.
If you want to export to PDF for the purpose of soft-proofing the document, you can apply the document’s color proofing settings. In addition, you can choose additional soft-proofing options, such as preserving document overprints and overprinting black.
To specify color management options for exporting PDF files |
1 |
Click File Export.
2 |
Choose PDF - Adobe Portable Document Format from the Save as type list
box.
3 |
Locate the folder in which you want to save the file.
4 |
Type a filename in the File name box.
5 |
Click Export.
The PDF settings dialog box appears. |
6 |
Click the Color tab.
7 |
In the Color management area, enable the Use document color settings option.
8 |
Choose a color profile option from the Output colors as list box:
RGB
CMYK
Grayscale
Native
If you choose the Native option from the Output colors as list box, a
maximum of three color spaces are displayed, or embedded, in the PDF file.
