You can import the following Microsoft Word files:
Microsoft Word Document (DOC) files from versions 97, 2000, 2002, 2003 as well
as files saved as DOC from Microsoft Word 2007 and 2010.
Microsoft Word Open XML Document (DOCX) files. This file format is based on
Open XML and uses ZIP compression. It was introduced with Microsoft Word
2007.
Rich Text Format (RTF) files. Rich Text Format (RTF) is a text format that stores
plain text and text formatting, such as bold. When you import an RTF file to
CorelDRAW, the text and any embedded Windows Metafile Format (WMF)
graphics are transferred. However, graphic elements are not transferred in an RTF
file exported from CorelDRAW.
Because Microsoft Word is a proprietary file format, it’s sometimes difficult to precisely import all aspects of a Microsoft Word file in CorelDRAW. To successfully import text with fewer inconsistencies, it is recommended that you install the Microsoft Office Compatibility Pack. If the Microsoft Office Compatibility Pack was not previously installed on your computer, you will be prompted to install it when you attempt to import text.
To import a Microsoft Word file | ![]() |
1 |
Click File ![]() |
2 |
Do one of the following:
(Windows 7 and Windows Vista) Choose DOC, DOCX - MS Word or RTF -
Rich Text Format from the All file formats list box.
(Windows XP) Choose DOC, DOCX - MS Word or RTF - Rich Text Format
from the Files of type list box.
3 |
Choose the drive and folder where the file is stored.
4 |
Click the filename.
5 |
Click Import.
If the Microsoft Office Compatibility Pack was not previously installed on your computer, the Install compatibility pack dialog box appears. The installation of the Microsoft Office Compatibility Pack is highly recommended. To proceed with the installation, click Ok and follow the instructions in the installation wizard. |
6 |
In the Importing/Pasting text dialog box, you can choose to maintain or discard
text formatting. You can also choose to import tables as tables or text.
7 |
Position the import cursor ![]() |
Any embedded Windows Metafile Format (WMF) or Enhanced Metafile
Format (EMF) graphics are preserved in the imported file. If the file contains
other graphic elements, these are lost during conversion and do not appear in
CorelDRAW.
You can place your imported text by dragging a marquee to define a paragraph
text box, or by pressing the Spacebar to place the imported text in the default
location.
If you import text and choose not to install the Microsoft Office Compatibility
Pack, the Install compatibility pack dialog box will reappear the next time
you import text, unless you enable the Do not ask me this question again check
box. You can reactivate the Install compatibility pack dialog box by clicking
Tools ![]() |
To export a Microsoft Word file | ![]() |
1 |
Open a drawing that contains a text object.
2 |
Click File ![]() |
3 |
Choose DOC - MS Word for Windows 97/2000/2002 or RTF - Rich Text
Format from the Save as type list box.
4 |
Type a filename in the File name list box.
5 |
Click Export.
The filename extension for the format you choose is appended to the filename
automatically.
Only text in drawings can be exported to the Microsoft Word file formats.
Other graphical elements, such as lines, curves, and rectangles, are lost during
conversion and do not display in the file. To export graphics, use a graphic
format such as WMF.
Microsoft Word (DOC, DOCX, and RTF) technical notes | ![]() |
The following Microsoft Word versions are supported: Microsoft Word 97-2010,
Microsoft Word for Windows 6/7, Microsoft Word for Windows 2.x, Microsoft
Word 3.0, 4.0, 5.0, and 5.5.
The embedded-field method for building indexes in Microsoft Word is supported,
but the style-implied method for building indexes is not.
The Corel program matches the fonts in the file you are importing with the same or
similar fonts, depending on the fonts installed on your computer. However, the
Normal text style in Microsoft Word is converted to the default text style. To set
the default text style, click Tools ![]() |
Whenever possible, the program automatically converts characters available in the
sets “Symbol” or “MS Linedraw” to the corresponding Windows character set
entries.
Most fonts are proportionally spaced, and text is reflowed when imported. As a
result, soft line and page breaks often appear in new locations if you are converting
to a fixed-pitch or nonscalable font.
When you import text, the page size in the original document is ignored. The text
is adjusted to fit the current page size, which may affect the placement of text.
If a table is longer then the current page, the table data continues down and off the
page.
Nested tables are not fully supported. The text within a nested table appears within
the text box of the top-level table cell as text only (no bounding lines).
Nested bullets are not fully supported.
Objects and graphs are not supported.
Equations are not maintained — the data and results may be maintained but they
are unlinked.
Text direction is not maintained.
