CorelDRAW lets you select text for to edit specific characters or modify it as an object. For example, you can select specific characters to change the font or select a text object, such as a text frame, so you can move, resize, or rotate it.
| To select a text object |
To
Do the following
Select artistic text
Using the Pick tool
Select a text frame
Using the Pick tool
You can use the Pick tool
| To select text for editing |
