Learn inspector
The Learn inspector lets you search and access various online learning resources such as practice projects, videos, Help topics, and written tutorials that can help you with your projects. To find the resources you need more easily, you can filter and sort your search results.
Complete your profile by answering questions about your experience with the product and the type of projects you create so that we can recommend learning resources that match your skill level, needs, and interests. You can access the profile survey when you start the application for the first time or from the Explore tab of the Learn inspector.
In addition, you can search local resources such as Hints and tooltips from within the Learn inspector. For information about how to access and use Hints, see Hints. For more information about tooltips, see Help and tooltips.
You can also give feedback and share ideas about the application from the Learn inspector. For more information, see Submit feedback.
To find learning resources
Back to Top
1 Click Help Learn.
2 In the Learn inspector, click the Explore button .
If you haven’t completed your profile, click the Personalize results button , and answer the questions in the survey.
3 In the Search box, type a search term, and press Return.
To delete the search term, click the Clear search button (X).
You can also
Filter search results
Click the Filter button, and disable any of the following filters: Tool Hints, Practice Projects, Written Tutorials, Videos, and Help Topics.
Sort search results
From the Sort list box, choose one of the following options:
• Most Recent — sorts learning materials by the date they were created, starting with the most recent one
• Recommended for you — sorts learning materials based on your profile, starting with the ones that best match your needs, interests, and skill level
• Most Relevant — sorts learning materials based on their relevance to the search term you typed
You must be signed in to access the Explore tab.
You can also access the profile survey from the Privacy page of the Preferences dialog box. For more information, see Your privacy and profile.
