Converting a vector graphic or object to a bitmap lets you apply special effects to the object with Corel DESIGNER. The process of converting a vector graphic to a bitmap is also known as "rasterizing."
Dithered — simulates a greater number of colors than those available. This option is available for images that use 256 or fewer colors.
Always overprint black — overprints black when black is the top color. Enabling this option prevents gaps from appearing between black objects and underlying objects when you print bitmaps.
Always overprint black — overprints black when black is the top color. Enabling this option when you print bitmaps prevents gaps from appearing between black objects and underlying objects.
