Export files
To export a file
To export a file to Microsoft Office or WordPerfect Office
To save a file to a different format
You can use the File Export command to export files to a variety of bitmap and vector file formats that can be used in other applications. For example, you can export a file to the Adobe Illustrator (AI) or JPG format. You can also export a file so that it is optimized for use with a suite of office productivity applications, such as Microsoft Office or Corel WordPerfect Office.
When you are exporting a file, the original file is left open in the drawing window in its existing format.
You can use the File Save as command to save files to various vector formats. After you save a file to a different format, the saved file is displayed immediately in the drawing window. It is recommended that you first save the file as a Corel DESIGNER file because some file formats do not support all of the features found in a Corel DESIGNER file.
To export a file Back to Top
Choose a compression type from the Compression type list box.
Not all of the options or compression types in the Export dialog box are available for all file formats.
Objects on a hidden layer are displayed in the exported file unless the printing and exporting function for the hidden layer is disabled.
For information about the options available when you export to a bitmap file format, see To convert a vector graphic to a bitmap when exporting.
If you are using an expired trial version, you will not be able to export files.
You can specify which layers will appear in the exported file. For more information, see To enable or disable printing and exporting of a layer.
To export a file to Microsoft Office or WordPerfect Office Back to Top
Using the Zoom in or Zoom out tool, click in the preview window.
Using the Pan tool , drag in the preview window until the area that you want to see becomes visible.
The optimization options are available only if you choose the Microsoft Office and Compatibility options.
Layers in a drawing are flattened when exported to Microsoft Office or Corel WordPerfect Office.
To save a file to a different format Back to Top
Not all of the options or the compression types in the Save drawing dialog box are available for all file formats.
