Working with registry keys
After creating the server image, you may want to edit its registry keys for deployment to the workstations. By doing so, you can avoid having to manually configure the registry keys of each individual workstation installation of the software.
Setting up dynamic language switching
Dynamic language switching allows the language of the user interface to be changed, both during and after installation. This feature requires the installation of multiple language modules for the software — one for each desired user-interface language (see Specifying UI modules by language code). The selection of languages you can implement depends on the license you have purchased.
Two sets of registry settings are required for dynamic language switching:
workstation settings
current user settings
Workstation settings
Workstation settings affect all users. The registry setting for each workstation is as follows:
HKEY_LOCAL_MACHINE\SOFTWARE\Corel\Corel DESIGNER\25.0\Languages
Inside this key are language keys — three-letter codes that represent the available languages. These language keys are put in place by the setup, so no intervention is required. Shown here (for reference only) are the three-letter codes for the available languages for the remaining components.
Language
Code
Brazilian Portuguese
PTB
Chinese (Simplified)
CHS
Chinese (Traditional)
CHT
Czech
CSY
Dutch
NLD
English
ENU
French
FRA
German
DEU
Italian
ITA
Japanese
JPN
Polish
PLK
Russian
RUS
Spanish
ESN
Swedish
SVE
Turkish
TRK
Under each language key are the following registry settings:
DirName — specifies the name of the folder for the language-specific files, relative to InstallationPath\Languages
UIName — specifies the name to show in the startup dialog box and on the Tools Options Global dialog box (General page)
Current user settings
The registry setting for each current user is as follows:
HKEY_CURRENT_USER\Software\Corel\Corel DESIGNER\25.0
The UILang setting is not initialized by the setup because the setup cannot determine which user will run the applications. After the user has run the application once, this setting changes to the three-letter code that corresponds to the user-specified language key at the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Corel DESIGNER\25.0\Languages
