Corel DESIGNER (CorelDRAW Technical Suite June 2024 Subscriber Update)
CorelDRAW Technical Suite June 2024 Subscriber Update offers a range of enhancements, including:
The improved Brush picker lets you quickly search for Painterly brushes by typing the name of a brush style or brush category. For more information, see To search for brushes. The new My media count at the top of Brush picker displays the number of brushes. The default size of the Brush picker has been increased, and you can also easily resize it to suit your creative workflow. For more information, see To resize the Brush picker. Additionally, expanded and collapsed brush categories are now retained between sessions.
The settings for several Painterly brushes have been optimized to make them more memory-efficient, especially when used at their largest size.
You can now purchase additional Painterly brush packs from within the Welcome Screen or the Brush picker. For more information, see Acquire more brushes.
Updated! Corel DESIGNER (DES) file format
The default Corel DESIGNER (DES) file version is now 25.1 (2024.1). You can save a drawing that is compatible with an earlier version (including the March 2024 release) of CorelDRAW Technical Suite (File Save As Version list box) and specify save options (Advanced). Such options are useful when the file contains new Painterly brushstrokes, text, fill, outline, or transparency features that are not supported in earlier versions.
Updated! File Locations options
When Corel DESIGNER cannot locate content folders that have been renamed, moved, deleted or disconnected, a new message displays information on how to correct the issue.
Content Type folders that have been renamed, moved, deleted or disconnected and require updating are now indicated by an icon in the Options dialog box (Tools Options Global File Locations).
Enhanced! PDF import
When importing a PDF file containing text, the new Maintain paragraphs, text flow, and formatting option is selected by default. This option delivers the best text-editing experience by organizing blocks of text into full paragraphs. Disabling this option reverts to the legacy text-importing behavior used in earlier versions of the application, where imported text objects remain grouped in smaller artistic text runs. This maintains the explicit kerning, spacing, sizing, and effects specified in the PDF file. For more information about importing PDF files, see Adobe Portable Document Format (PDF).
