Use templates
When you start a document from a template by using the File New from Template command, Corel DESIGNER formats the page according to the page layout settings in the template and then loads all objects and template’s styles into the new document. With this method, you can search and browse for templates.
If you want to use only the styles from a template, you can create a blank document by using the File Open command.
You can also import styles from a template into a document at any time.
To start a document from a template
Back to Top
1 Click File New from Template.
2 Click one of the following buttons:
• Corel online templates — shows templates in the Corel online library
• Local templates — shows local and network templates
3 Search or browse for templates.
4 Choose a template by clicking a thumbnail in the preview pane.
5 Click Open.
For information about searching for templates, see To find, filter, and sort templates.
You can also start a drawing from a template by clicking File New, clicking the Templates tab, and choosing a template.
You can also start a document from a template by clicking File Open, locating the template, double-clicking it, and enabling the New from template option in the Open dialog box. If you want to use only the template’s styles, disable the With contents check box.
To import styles from a template into a document
Back to Top
1 Click Window Dockers Object Styles.
2 In the Object Styles docker, open the Import, export, or save defaults flyout, and then click the Import style sheet button .
3 Locate the folder where the template is stored.
4 Click the template that contains the styles that you want to load.
5 Click Import.
6 In the Import Styles dialog box, enable the check boxes for the settings you’d like to import into the document.
Only the template styles are imported. Page layout settings and objects saved with the template are ignored. The attributes of existing objects are maintained.
