Changing image dimensions
You can change the physical dimensions of images by increasing or decreasing their height and width. When you increase image dimensions, the application inserts new pixels between existing pixels, and their colors are based on the colors of adjacent pixels. If you increase image dimensions significantly, images may appear stretched and pixelated.
The size of the image on your screen depends on the pixel height and width of the image, on the zoom level, and on your monitor settings. As a result, an image may display as a different size on your screen than when it is printed.
You can change the height and width of an image without changing the resolution. Left to right: image with smaller dimensions, original image, image with larger dimensions.
To change the dimensions of an image Back to Top
Click Image Resample.
Enable any of the following check boxes:
Anti-alias — smooths the edges in the image
Maintain aspect ratio — avoids distortion by maintaining the width-to-height ratio of the image
In the Image size area, type values in one of the following pairs of boxes:
Width and Height — let you specify the image dimensions
Width % and Height % — let you resize the image to a percentage of its original size
When you change the dimensions of an image, you produce better results using width and height values that are factors of the original values. For example, reducing image size by 50% produces a better-looking image than reducing image size by 77%. When reducing an image by 50%, the application removes every other pixel; to reduce an image by 77%, the application must remove pixels irregularly.
