Computer Graphics Metafile (CGM)
Computer Graphics Metafile (CGM) is an open, platform-independent metafile format used for storing and exchanging two-dimensional graphics. It supports RGB color. CGM files can contain both vector graphics and bitmaps, but they usually contain one graphic type or the other — rarely both.
To import a CGM file Back to Top
Click File Import.
Locate the folder in which the file is stored.
Do one of the following:
(Windows 7 and Windows Vista) Choose CGM - Computer Graphics Metafile (*.cgm) from the list box next to the File name box.
(Windows XP) Choose CGM - Computer Graphics Metafile from the Files of type list box.
4
Click the filename.
5
Click Import.
The Convert to bitmap dialog box appears.
Computer Graphics Metafile (CGM) technical notes Back to Top
You can import files formatted in CGM versions 1, 3, and 4.
The CGM filter accepts only markers supported by the CGM file format standard. Private-use markers are ignored.
If the CGM file contains a font that is not on your computer, the PANOSE font- matching dialog box lets you replace the font with an available one.
