WordPerfect Graphic (WPG)
The Corel WordPerfect Graphic file format (WPG) is primarily a vector graphic format, but it can store both bitmap and vector data. The WPG files may contain up to 256 colors, chosen from a palette of more than 1 million colors.
To import a WordPerfect Graphic file Back to Top
Click File Import.
The File Import command lets you place the file as an object in the active image. If you want to open a WPG file as an image, click File Open.
Locate the folder in which the file is stored.
Click the filename.
4
Click the image window.
WordPerfect Graphic (WPG) technical notes Back to Top
Graphics Text Type 2 is not supported.
