You can choose background, foreground, and fill colors by selecting a color from the color control area, color palettes, color viewers, color harmonies, or color blends and by sampling colors from an image.
For information about applying the colors you choose, see Applying uniform fills, Drawing and painting, and Working with objects.
A color palette is a collection of color swatches. In some programs, color palettes are known as "swatch palettes."
You can choose foreground, background, and fill colors by using the default color palette, which contains colors from the RGB color model.
When you create a new image, the application automatically generates an empty palette, called the Image palette. It helps you keep track of the colors that you use by storing them for future use. For more information, see Using the Image palette.
Palette libraries and custom color palettes
The color palettes that are found in the Palette libraries cannot be edited directly. Some of them are provided by third-party manufacturers, for example PANTONE, HKS Colors, and TRUMATCH. It may be useful to have on hand a manufacturer’s swatch book, which is a collection of color samples that shows exactly what each color looks like when printed.
Some palettes found in the Palette libraries — PANTONE, HKS Colors, TOYO, DIC, Focoltone, and SpectraMaster — are collections of spot colors. If you create color separations when you print, each spot color requires a separate printing plate, which can significantly affect the cost of the printing job. If you want to use color separations but would like to avoid using spot colors, you can convert the spot colors to process colors when printing. For more information, see Printing color separations.
Custom color palettes can include colors from any color model, including palettes found in the Palette libraries, such as a spot color palette. You can save a custom color palette for future use. For more information about working with custom color palettes, see Creating and editing custom color palettes.
When you sample a color from a photo, what looks to be a solid-colored area may actually be subtly shaded or dithered. In this case, it is useful to average the colors of pixels in a larger sample area. You can set the sample area to 3 × 3 pixels, or to 5 × 5 pixels for high-resolution images. You can also sample pixels in a selected area.
If you want to sample and use numerous colors from the image window, you can store them on a custom color palette. For more information on custom color palettes, see Creating and editing custom color palettes.
Color viewers provide a representation of a range of colors by using either one-dimensional or three-dimensional shapes. The default color viewer is based on the HSB color model, but you can use this viewer to choose CMYK, CMY, or RGB colors. For information about color models, see Understanding color models.
You can use web colors when you design documents that will be published to the web. With Corel PHOTO-PAINT, you can define web colors by using RGB hexadecimal values (for example, #aa003f).
| To choose a color by using the color control area |
| 1 . | In the color control area of the toolbox, double-click one of the following: |
| • | Foreground color swatch ![]() |
| • | Background color swatch ![]() |
| 2 . | Move the color slider to set the range of colors displayed in the color selection area. |
| 3 . | Click in the color selection area to choose a color. |
Double-click the Fill color swatch in the color control area, click the Uniform fill
Click the Reset color icon
You can also choose foreground, background, and fill colors by using the Color docker. To open the Color docker, click Window
Dockers
Color.
| To choose a color by using the default color palette |
Hold down Ctrl, and click a color swatch.
You can display color names by pointing to a swatch.
Dockers
Color.
An example of a pop-up color palette
| To choose a color by using a color palette |
| 2 . | Click the Palettes tab |
| 3 . | Choose a color palette from the Palette list box. |
| 4 . | Move the color slider to set the range of colors displayed in the color selection area. |
| 5 . | Click a color in the color selection area. |
in the color control area, click the Uniform fill button |
Click Options
Each spot color swatch on a color palette is marked with a small white square.
You should use the same color model for all colors in an image; the colors will be consistent, and you will be able to predict the colors of the final output more accurately. For more information about reproducing colors accurately, see Using color management.
You can also access color palettes in the Color docker by clicking the Show color palettes button, and choosing a palette from the list box. If the Color docker is not open, click Window
Dockers
Color.
| To sample a color |
| 1 . | Click the Eyedropper tool |
| 2 . | Click the image to choose a foreground color. |
| The default sample size is 1 pixel. |
Click the 3 × 3 button
Click the 5 × 5 button
Click the Select sample button
Press Control, and click the image.
In the image window, a preview swatch is attached to the Eyedropper tool, along with an information box listing the color model component values. When you sample an RGB color, the information box also includes the hexadecimal color value.
You can also activate the Eyedropper tool by pressing the E key. Click the Spacebar to return to the previously selected tool.
You can also use the Image info docker to view the color model component values for an image pixel, such as the red, green, and blue components of a pixel in an RGB image or its hexadecimal color value. If the Image info docker is not open, click Window
Dockers
Info.
| To choose a color by using a color viewer |
| 2 . | Click the Models tab |
| 3 . | Choose a color model from the Model list box. |
| 4 . | Click Options, choose Color viewers, and click a color viewer. |
| 5 . | Move the color slider. |
| 6 . | Click a color in the color selection area. |
Click Options, and choose Swap colors. This swaps the Old color (the current foreground or background color) and the New color (which has been chosen in the color selection area).
If you choose a color that is outside of the printer gamut, Corel PHOTO-PAINT allows you to replace it with a similar color that is in the printer’s gamut. To replace the color, click the Bring color into gamut button, which appears to the left of the New color swatch. For information about color correction, see Using color management.
You should use the same color model for all colors in an image; the colors will be consistent and you will be able to predict the colors of the final output more accurately.It is preferable to use the same color model in your drawing that you will be using for the final output.
When you choose a color that is out of the printer’s gamut, the Bring color into gamut button appears below the Eyedropper button.
You can choose a fill color by double-clicking the Fill color swatch
in the color control area. Click the Uniform fill button in the Select fill dialog box, and click Edit.
You can swap the Old color (the current foreground or background color) and the New color (which has been chosen in the color selection area) by clicking Options
Swap colors.
You can also access color models in the Color docker by clicking the Show color viewers button and choosing a color model from the list box. If the Color docker is not open, click Window
Dockers
Color.
| To choose a color by using color blends |
| 2 . | Click the Mixers tab. |
| 3 . | Click Options, choose Mixers, and then click Color blend. |
| 4 . | Open each color picker, and click a color. |
Only colors that are on the default color palette can be blended. To blend other colors, you must change the default color palette.
| To choose a web color |
| 1 . | Click Window |
| 2 . | In the Color docker, click the Fill, Background, or Foreground color swatch and choose Default RGB palette from the list. |
| 3 . | Type or paste a value in the Hex value box. |
| Whether you use a three-digit (#fff) or six-digit format (#ffffff), the final value is presented in the six-digit format. |
You can specify hexadecimal color values only when working with RGB colors.
If you type an invalid hexadecimal value, the color does not change.
You can view hexadecimal color values on the status bar.
You can also choose web colors from the Foreground color, Background color, or Uniform fill dialog boxes. These dialog boxes also let you view and copy the hexadecimal equivalents of non-RGB colors.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
