Managing paths
Saving, exporting and deleting paths
You can save one or more paths with an image when you save the image to the Corel PHOTO-PAINT (CPT) file format. You can also export paths for use in other applications, such as CorelDRAW (CDR) or Adobe Illustrator (AI). If you want to use a path in other Corel PHOTO-PAINT images, you must export the path to the Corel Presentation Exchange (CMX) file format. You can delete a path at any time.
Importing paths and vector graphics
You can import a path into a Corel PHOTO-PAINT image. You can open more than one path and switch between them in the image window. Corel PHOTO-PAINT also lets you import vector graphics from other drawing applications. When vector graphics are converted to paths, each point on the vector is converted to a node. To import text from CorelDRAW, you must first convert the text to curves.
Viewing a path
By default, a path displays in black. You can hide a path when you are working on an image, or you can change the default color of the path to make it more visible.
To save a path with an image Back to Top
You must export a path if you want to use it in other Corel PHOTO-PAINT images or other applications. For information about exporting paths, see To export a path.
To export a path Back to Top
To delete a path Back to Top
To import a path or vector graphic Back to Top
Large, complex vector images are not suitable for importing as paths, because they contain too many nodes.
To hide a path Back to Top
To change the default path color Back to Top
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
