You can save time by using a macro to automate a series of repetitive tasks. A macro lets you specify a sequence of actions so that you can quickly repeat those actions later.
You don’t need any programming experience to use macros — in fact, the basic tools for working with macros are available within the main application window. However, if you want to have more control over your macros, you can use the following built-in programming environments:
For detailed information on the differences between VBA and VSTA, please see the programming guide on the Developer area on the CorelDRAW community website.
Getting started with macros
The macro features for VBA and VSTA are installed with the software by default, but you can manually install these features if necessary. You can specify options for the VBA feature.
To use VSTA macro features with Corel PHOTO-PAINT, you must have Microsoft Visual Studio 2017 installed. To use the VSTA Editor, you must first install Microsoft Visual Studio 2017, Community, Professional, Premium, Ultimate or Enterprise Edition; and then reinstall Microsoft Visual Studio Tools for Applications 2017 from microsoft.com.
If you install Microsoft Visual Studio after installing CorelDRAW Graphics Suite, you must re-install the VSTA macro features by modifying your installation. For more information, see To manually install the macro features.
The macro features provide several tools for working with macros in the main application window:
Creating macros
Macros are stored in modules (also called "code modules"), which are stored in macro projects. The Macro Manager docker lets you view and manage all of the macro projects, modules, and macros that are available to you.
You can use the Macro Manager docker to create macro projects in the form of Global Macro Storage (GMS) files or Corel VSTA Projects (CGSaddon). Using such files is an excellent way to bundle the components of your macro project for sharing with others. You can use the Macro Manager docker to open (or "load") the macro projects that you create, as well as the macro projects that install with the software or that are otherwise made available to you. You can also use the Macro Manager docker to rename macro projects, as well as to copy and close (or "unload") GMS-based and VSTA macro projects.
Some macro projects are locked and cannot be modified.
When you create a document, a macro project for that document is automatically added to the Macro Manager docker. Although you can store macros within the macro project for a document — for example, to create an all-in-one template — it is recommended that you instead use GMS files to store your macro projects.
Each macro project contains at least one module. You can use the Macro Manager docker to add a module to a VBA-based macro project, or to open existing modules for editing. You can also use the Macro Manager docker to rename or delete VBA modules.
The editing feature is disabled for some modules.
Finally, you can use the Macro Manager docker to create macros within the available modules. You don’t need any programming experience to create macros; however, if you have programming experience and want to edit VBA macros, you can do so by using the Macro Editor. You can also use the Macro Manager docker to rename and delete VBA macros.
Playing macros
You can perform the actions that are associated with a macro by playing that macro.
Learning more about macros
The Developer area on the CorelDRAW community website can help you with its wealth of useful resources: a programming guide, detailed Object Model reference documentation with code samples, object model diagrams, and in-depth programming articles and tutorials.
The Object Model reference documentation, also referred to as API documentation, includes help on every feature and function that can be automated in the applications. (Collectively, these features and functions are called an "object model.") You can easily access relevant documentation from within the Macro Editor.
The Object Model diagrams provide a hierarchical representation of the features and functions that can be automated in CorelDRAW, Corel PHOTO-PAINT, and Corel DESIGNER.
For more detailed information about VBA and its programming environment, please consult the Microsoft Visual Basic Help from the Help menu in the Macro Editor.
For more detailed information about VSTA and its programming environment, please consult the Help menu in the VSTA Editor.
| 2 . |
Double-click CorelDRAW Graphics Suite on the Uninstall or change a program page. |
| 3 . |
Enable the Modify option in the wizard that appears, and follow the instructions. |
| 4 . |
On the Features page of the installation wizard, enable the following check boxes in the Utilities list box: |
The macro features for VBA and VSTA are installed with the software by default.
| 2 . |
In the Workspace list of categories, click VBA. |
| 3 . |
In the Security area, specify how to control the risk of running malicious macros by clicking Security options. |
| 4 . |
On the Security level page of the Security dialog box, enable one of the following options: |
Very high — allows only macros installed in trusted locations to run. All other signed and unsigned macros are disabled. |
High — allows only signed macros from trusted sources to run. Unsigned macros are automatically disabled. |
Medium — lets you choose which macros run, even if they are potentially harmful |
Low (not recommended) — allows all potentially unsafe macros to run. Enable this setting if you have virus-scanning software installed, or if you check the safety of all documents that you open. |
| 5 . |
On the Trusted publishers page of the Security dialog box, review which macro publishers are trusted. Click View to display details on the selected macro publisher, or click Remove to delete the selected macro publisher from the list. |
| 6 . |
Disable the Delay load VBA check box if you want to load the VBA feature at start-up. |
In the Macro Manager docker, do one of the following: |
Click Visual Studio Tools for Applications in the list, click New, and then click New macro project. |
Click Visual Basic for Applications in the list, click New, and then click New macro project. |
Click Visual Studio Tools for Applications in the list, click Load, and then choose the project. |
Click Visual Basic for Applications in the list, click Load, and then choose the project. |
Right-click the project in the list, click Copy to, and then choose the target location for the copied project.
NOTE: You cannot copy a document-based macro project. Such projects are stored within a document and cannot be managed separately from that document.
Click the Simple mode button  .
NOTE: You can close a document-based macro project only by closing the document in which it is stored.
Click Tools Macros Run macro, or click the Run macro button on the Macros toolbar. From the Macros in list box, choose the project in which the macro is stored. From the Macro name list, choose the macro. Click Run. |
In the Macro Manager docker, double-click the macro in the list. |
In the Macro Manager docker, click the macro in the list, and then click the Run button . |
In the Macro Manager docker, right-click the macro in the list, and then click Run. |
| 2 . |
Choose PHOTOPAINT from the Library list box. |
You can also display information for any item in the Code window of the Macro Editor by clicking that item and pressing F1.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
