Adobe Photoshop (PSD)
The Adobe Photoshop (PSD) file format is the native bitmap file format for Adobe Photoshop.
To import an Adobe Photoshop file
Click
File
Import.
The
File
Import command lets you place the file as an object in the active image. If you want to open a PSD file as an image, click
File
Open.
Locate the folder in which the file is stored.
Choose
PSD - Adobe Photoshop (*.psd; *.pdd) from the list box next to the
File name box.
6
Click the image window.
Resample a graphic while importing
Crop a graphic while importing
To export an Adobe Photoshop file
Click
File
Export.
Locate the folder in which you want to save the file.
Choose
PSD - Adobe Photoshop from the
Save as type list box.
4
Type a filename in the
File name list box.
You can preserve Corel PHOTO-PAINT objects as layers in the PSD file format.
If you are exporting a 16-bit grayscale or 48-bit RGB file for use in Adobe Photoshop versions CS and earlier, choose Uncompressed from the Compression type list box. Adobe Photoshop versions CS and earlier do not support compressed 16-bit grayscale and 48-bit RGB files.
Adobe Photoshop (PSD) technical notes
Importing a PSD file
Text is imported as a text object, so it remains editable.
Monotone, grayscale, duotone, 48-bit RGB, and up to 32-bit CMYK images are supported.
Some layer effects cannot be imported. (Gradient map adjustment layer is imported without Noise, Opacity stops, and Dither.)
Imported layers using the Darken Color and Lighten Color blend modes map to the If Darker and If Lighter merge modes, respectively. For more information about working with merge modes in Corel PHOTO-PAINT, see
Merge modes.
Smart Filter effects are imported as a base object stacked with separate filter effects.
The Vibrance adjustment layer maps to the Vibrance lens.
The Black-and-white adjustment layer maps to the Grayscale lens.
The Channel Mixer adjustment layer maps to the Channel Mixer lens.
The Gradient Map adjustment layer maps to the Gradient Map lens; however, opacity stops, dithering, and noise adjustments are not supported.
The Photo Filter adjustment layer maps to the Photo Filter lens.
Spot color channels are preserved. Alpha channels with spot color channels applied to them are not supported.
A layer mask that has density applied to it imports as a clip mask with the transparency adjusted. However, you can’t change the density settings in Corel PHOTO-PAINT.
A layer mask that has feathering applied to it imports as a clip mask with the feathering applied. However, you can’t change the feathering settings in Corel PHOTO-PAINT
Exporting a PSD file
Text is exported as a text object, so it remains editable.
This format supports 1-bit black and white, duotone, 16-bit grayscale, 48-bit RGB, and up to 32-bit CMYK color images.
32-bit floating point color channels are mapped to 16-bit channels, which cannot be exported as 32-bit High Dynamic Range (HDR) images.
Smart Filter effects are not retained when imported and are not replaced when exported.
Spot color channel information is preserved in the exported file.
