Create and edit color palettes
Custom color palettes are collections of colors or color styles that you save. They can include colors or color styles from any color model, including spot colors, or any color palette found in the Palette libraries. You can create a custom palette to store all colors or color styles that you need in a current, or future, project.
It’s easy to share color palettes with others. The custom palettes are accessible from the My palettes folder in the Palettes docker.
You can create a custom color palette by choosing individual colors, or by using colors in an object, an editable area, or an entire image. You can also add custom spot colors to any custom palette. You can also edit, rename, and delete custom color palettes.
Custom color palettes are saved as XML files and are stored in your Documents\Corel\Corel Content\Palettes folder.
To create a custom color palette from scratch
Click
Window
Color Palettes
Palette Editor.
Click the
New palette button.
Type a filename in the box.
5
In the
Palette editor dialog box, click
Add color.
6
In the
Select color dialog box, choose a color, and click
OK.
Treat the color as a spot color
In the Selected color area of the Palette editor dialog box, choose Spot from the Treat as list.
Treat the color as a process color
In the Selected color area of the Palette editor dialog box, choose Process from the Treat as list.
In the Palette editor dialog box, click a color in the color selection area, and type a name in the Name box.
When dragging an image to the Image palette, only the five most dominant colors are added. Colors from PostScript fills are not supported.
To create a color palette from an editable area
Click
Window
Color Palettes
Create Palette from Visible.
Click
Save palette as
For information about defining editable areas, see Define editable areas.
To create a color palette from an image
Click
Window
Color Palettes
Create Palette from Document.
To edit a custom color palette
Click
Window
Color palettes
Palette Editor.
Choose a
palette from the list box.
Perform a task from the following table.
Click Add color. In the Select color dialog box, click the Models tab, click a color in the color selection area, and click Add to palette.
Treat a color as a spot color
Treat a color as a process color
In the color selection area, click a color, and click Edit color. In the Select color dialog box, click a new color in the color selection area.
In the color selection area, click a color, and click Delete color.
Click Sort colors, and choose a color sorting method.
Drag a color swatch to a new position.
Click a color in the color selection area, and type a name in the Name box.
You can delete multiple colors by holding down Shift or Ctrl, clicking the colors that you want to delete, and clicking Delete color.
To rename a custom color palette
Click
Window
Color Palettes
Palettes.
Type a new name, and press
Enter.
To delete a custom color palette
Click
Window
Color Palettes
Palettes.
From the
My Palettes folder, right-click a custom
palette, and click
Delete.
