You can change the shape of a path by selecting and moving its nodes, segments, or control points.
You must select a node before you can move it to another location, delete it, or drag its associated control points. Selecting several nodes lets you perform the same operation simultaneously on one or more path segments.
You can move path segments by dragging nodes. When you drag a single node, the segments attached to it move with the node and remain connected. When you drag two or more adjacent nodes, the path segments between the nodes retain their form and move with the nodes.
Rotating and skewing path segments
Rotating paths lets you turn them around a pivot point, called the center of rotation, whereas skewing paths lets you slant them to one side while the opposite side remains stationary.
You can change the length or width of the path segments that you select, and you can scale selected path segments. When you scale path segments, they can either keep their proportion or become distorted as you size the path.
Reshaping a curve segment by using control points
When you select a single node on a curve segment, two control points extend from it in opposite directions. You can change the shape of a curve by repositioning the control points. You may need to change the node type to achieve the shape you want. For more information about node types, see Change node types.
You can also select multiple nodes by clicking the Shape button and marquee selecting a group of nodes.
You can deselect a node by holding down Shift and clicking a node.
You can move path segments in precise increments by pressing an Arrow key to move the selected nodes the nudge distance, or by holding down Shift and pressing an Arrow key to move the selected nodes the super nudge distance.
You can also drag the center of rotation to a new location.
You can also size path segments by clicking the Elastic mode button on the property bar.
