Styles and style sets
CorelDRAW provides advanced style capabilities that allow you to format your documents with speed, ease, and consistency. You can create and apply styles and style sets to different types of objects: graphic objects, artistic and paragraph text, callout and dimension objects, and any objects created with the Artistic Media tools.
Styles and style sets are groups of attributes that determine the appearance of objects. When you apply a style or style set to an object, all the attributes defined in that style are applied to the object in one step. That is how you can format simultaneously many different objects and significantly reduce your set-up and production time. What is more, when you edit a style or style set, all the objects defined by that style are automatically updated.
You can also export styles and style sets as style sheets for use in other documents, or import them from previously saved style sheets.
Styles simplify the task of formatting objects by saving time and ensuring a consistent look.
This section includes the following topics:
Create styles and style sets
Apply styles and style sets
Edit styles and style sets
Manage and apply default object properties
Export and import style sheets
Find objects that use a specific style or style set
Break the link between objects and styles or style sets
