Artistic and paragraph text can be shifted vertically or horizontally, or rotated, to create interesting effects. You can straighten text into its original position, and you can return vertically shifted characters to the baseline. You can also mirror artistic and paragraph text.
If you want to adjust the position of an entire text object that is fitted to a path such as a circle or a freehand line, see To adjust the position of text that is fitted to a path.
Rotated characters
| To shift or rotate a character |
1 |
Using the Text tool |
2 |
Click the Character shift arrow in the Character formatting docker, type a value
in one of the following boxes:
Angle — A positive number rotates characters counterclockwise, and a negative
number rotates characters clockwise.
Horizontal shift — A positive number moves characters to the right, and a
negative number moves characters to the left.
Vertical shift — A positive number moves characters up, and a negative number
moves characters down.
If the Character formatting docker does not appear in your workspace, click Text |
You can also use the Shape tool |
| To straighten a shifted or rotated character |
1 |
Select the text.
2 |
Click Text |
| To return a vertically shifted character to the baseline |
1 |
In the toolbox, click the Shape tool |
2 |
3 |
Click Text |
| To mirror text |
1 |
2 |
On the property bar, click one of the following buttons:
Mirror text horizontally |
Mirror text vertically |
You can also mirror text fitted to a path. For more information, see To mirror
Left to right: Text in original form, mirrored vertically, and mirrored horizontally
| To flip text by dragging diagonally |
1 |
2 |
Drag a corner selection handle across the text and past the corner handle on the
opposite side.
