When you are applying a pattern fill, you can access the online collection of full-color (vector) and bitmap pattern fills included in Corel Content. When you find a pattern fill that you like, you can download it.
For more information about pattern fills, see Applying pattern fills.
| To apply an online pattern fill |
1. |
Select an object.
2. |
Click Edit |
3. |
In the Object properties docker, click the Pattern fill button
4. |
In the Type area, click one of the following buttons:
Full-color pattern fill button
Bitmap pattern fill button
5. |
To access and use an online pattern fill, open the fill picker, and click More.
6. |
In the dialog box that appears, perform one or more tasks from the following table.
Online pattern fills appear watermarked if you have not signed in or do not
have the required membership. To sign in, click the Sign in/Sign out button
in the upper-right corner of the dialog box. For information about
memberships, see CorelDRAW memberships.
