With the Corel CONNECT docker, you can browse for content, or you can search for content by using keywords.
You can browse and search for content in one or multiple locations on your computer or local network as well as online. You can also navigate to previously viewed content.
You can search by the name, category (for example, clipart, photo images, or fonts), or reference information (for example, tags or notes) associated with a file. When you type a term in the Search and Address box and initiate a search, all matching files are displayed as thumbnail images in the viewing pane. For example, if you type flower, the application automatically filters out all files that do not match, and you see only the files that have the word flower in the filename, category, or tags assigned to the file. You can also type phrases and multiple words, and you can fine-tune your search by using Boolean operators such as AND, NOT, and OR. For example, you can find content that contains both flower and sun images by typing flowers AND sun. For information about adding tags and reference information, see To add drawing information.
To increase search speed for local content and improve results, you can adjust Windows Search options by adding more locations to the index.
You can also find all images on a Web page by typing the Web address. For example, typing www.corel.com displays all the images that appear on the Corel Web site.
By default, your search results include all relevant content such as vector graphics, bitmaps, and fonts. You can narrow the search results by excluding content. For example, if you are searching for graphics, you can display only vector graphics or bitmaps. If you need to choose a font for your project, you can display only fonts.
You can widen the scope of a search, and you can cancel a search at any time.
You can also browse and search for clipart and other content from previous versions of the suite by using the Scrapbook docker. Note that you cannot use the Scrapbook docker to search for content that is provided with CorelDRAW Graphics Suite X6.
The Scrapbook docker is not part of the default workspace and is available only through customization. To display the Scrapbook docker, see To add or remove an item on a toolbar.
| To browse for content |
Click a location in one of the following panes:
Libraries — lets you browse online and local content
Favorite folders — lets you browse your favorite locations
Folders — lets you browse the folder structure available on your computer
You can browse the contents of only one folder at a time.
| To search for content |
1. |
Click a location in any of the following panes:
Libraries — lets you search for online and local content as well as content on a
CD or DVD
Favorite folders — lets you search for content in your favorite locations
Folders — lets you search for content in the folder structure available on your
computer
2. |
Type a word or multiple words in the Search and Address box, and press Enter.
Files that match the search terms appear in the viewing pane. |
If you want to search for a phrase, enclose the phrase with quotation marks. |
Clicking a Show/Hide arrow (1) lets you show or hide the search results for a specific location.
When you search for online content, only vector files and bitmaps are included
in the search results.
If you want to browse the folder where a file is stored or access the source Web
page of an image, right-click the file, and click Open source location.
To search for content by using the Scrapbook docker, click Scrapbook |
| To find all images on a Web page |
Type a Web address (for example, www.corel.com) in the Search and Address
box.
| To refine your search |
On the Filter toolbar, click one of the following buttons:
Folders
Vectors
Bitmaps
Fonts
Other
A category is included in the search results if the button appears pressed.
| To navigate to previously viewed content |
Click the Navigate back
You can also go back to the previous search results by pressing Backspace.
You can also navigate to previously viewed content by clicking the Search and
Address bar drop-down arrow and choosing a location from the list. The
Search and Address bar keeps track only of the locations that you enter
manually.
| To stop a search |
Click the Cancel search button
