Combining two or more objects creates a single object with common fill and outline attributes. You can combine rectangles, ellipses, polygons, stars, spirals, graphs, or text so that they are converted to a single curve object. If you need to modify the attributes of an object that has been combined from separate objects, you can break apart the combined object. You can extract a subpath from a combined object to create two separate objects. You can also weld two or more objects to create a single object. For information about welding objects, see Welding and intersecting objects.
The two objects (left) are combined to create a single object (right). The new object has the fill and outline properties of the last object selected.
| To combine objects |
1. |
Select the objects to be combined.
2. |
Click Arrange |
Combined text objects become larger blocks of text.
You can also combine selected objects by clicking the Combine button
You can close open lines in a combined object by clicking Arrange |
| To break apart a combined object |
1. |
Select a combined object.
2. |
Click Arrange |
If you break apart a combined object that contains artistic text, the text breaks
apart into lines first, and then into words. Paragraph text breaks into separate
paragraphs.
| To extract a subpath from a combined object |
1. |
Click the Shape tool
2. |
Click the Extract subpath button
After you extract the subpath, the fill and outline properties of the path are
removed from the combined object.
