You can shift the characters of artistic and paragraph text vertically or horizontally or rotate them to create interesting effects.You can straighten characters into their original position, and you can return vertically shifted characters to the baseline. You can also mirror or flip artistic and paragraph text characters.
If you want to adjust the position of an entire text object that is fitted to a path, such as a circle or a freehand line, see To adjust the position of text that is fitted to a path.
Rotated characters
| To shift or rotate a character |
1. |
Using the Text tool
2. |
In the Object properties docker, click the Character button
To display the Object properties docker, click Window |
3. |
Click the arrow button
4. |
Type a value in one of the following boxes:
Horizontal character offset — A positive number moves characters to the
right, and a negative number moves characters to the left.
Vertical character offset — A positive number moves characters up, and a
negative number moves characters down.
Character angle — A positive number rotates characters counterclockwise, and
a negative number rotates characters clockwise.
You can also use the Shape tool
| To straighten a shifted or rotated character |
1. |
Using the Text tool
2. |
Click Text |
| To return a vertically shifted character to the baseline |
1. |
In the toolbox, open the Shape tool
2. |
Click the Shape tool
3. |
4. |
Click Text |
| To mirror text |
1. |
Using the Text tool
2. |
On the property bar, click one of the following buttons:
Mirror text horizontally
Mirror text vertically
You can also mirror text fitted to a path. For more information, see To mirror
Left to right: Text in original form, mirrored vertically, and mirrored horizontally
| To flip text by dragging diagonally |
1. |
Using the Text tool
2. |
Drag a middle selection handle across the text and past the corner handle on the
opposite side.
