Work with fills
To choose a default fill color
To remove a fill
To copy a fill to another object
To show fills in open curves
There are a number of tasks that are common to all types of fills. You can choose a default fill color so that every object that you add to a drawing has the same fill. You can also remove a fill, copy it to another object, or use it to fill an area surrounded by an open curve.
If you want to apply the same fill to other objects or simultaneously modify the fill attributes of multiple objects in a drawing, you can save the fill settings as a style. For more information about styles, see Styles and style sets. You can search for objects based on their fill and replace the existing fill with a new one. For more information, see Find and replace colors.
To choose a default fill color Back to Top
You can also change the default fill color by editing the default style sets in the Object Styles docker. For more information, see Manage and apply default object properties.
To remove a fill Back to Top
You cannot remove mesh fills by following this procedure. To remove a mesh fill from an object, select the object by using the Mesh fill tool , and click Clear Mesh on the property bar.
To copy a fill to another object Back to Top
You can also click the Interactive fill tool , select the object to which you want to copy a fill, click the Copy fill button on the property bar, and click the object from which you want to copy the fill.
You can also use the Attributes eyedropper tool to copy a fill. For more information, see To copy object properties from one object to another.
You can also sample the color of an existing object and apply the sampled color to another object as a uniform fill.
To show fills in open curves Back to Top
