You can modify existing tab stops by changing their alignment. You can also add trailing leader characters, so that dots, or other characters, automatically precede the tab stops. In addition, you can add new tab stops and remove existing tab stops.
Indenting changes the space between a text frame and the text that it contains. You can add and remove indents without deleting or retyping text. You can indent an entire paragraph, the first line of a paragraph, or all lines of a paragraph except the first line (a hanging indent). You can also indent from the right side of the text frame.
| To modify a tab stop |
1. |
Click Window |
2. |
In the Property manager docker, click the Paragraph button
3. |
In the Paragraph area of the Property manager docker, click the arrow button
4. |
Click the Tab settings button.
5. |
Perform a task from the following table.
You can also add, move, or delete tab stops on the horizontal ruler at the top
of the drawing window. Click to add a tab stop, drag a tab marker to move it,
and drag a tab marker off the ruler to delete it. For information about rulers,
see Using the rulers.
| To add a tab stop |
1. |
Using the Text tool
2. |
Click Window |
3. |
4. |
5. |
6. |
Click Add.
7. |
Click the new cell in the Tabs column, and type a value.
| To indent paragraph text |
1. |
Using the Text tool
2. |
Click Window |
3. |
4. |
In the Paragraph area of the Property manager docker, type values in the
following boxes:
First line indent — indents the first line of text relative to the left side of the
frame
Left line indent — creates a hanging indent relative to the left side of the text
frame; all lines, except the first line, are indented
Right line indent — indents the text relative to the right side of the frame
You can remove indents by typing 0 in the First line indent, Left line indent,
and Right line indent boxes.
You can indent an entire paragraph by typing the same value in both the First
line indent and the Left line indent boxes.
