You can apply PostScript texture fills to objects. A PostScript texture fill is created in the PostScript language. Some textures are very complex, and large objects that contain PostScript texture fills may take time to print or to update on the screen. Depending on the view mode you are using, the letters “PS” — rather than the fill — may appear. For more information about displaying PostScript fills, see Working with views.
When you apply a PostScript texture fill, you can change several properties, such as the size, line width, and the amount of gray that appears in the texture’s foreground and background.
| To apply a PostScript texture fill |
1. |
Select an object.
2. |
Click Edit |
3. |
In the Property manager docker, click the Postscript fill button
4. |
Choose a fill from the PostScript fill textures list box.
If you want to change the fill properties, click the PostScript fill properties button
You can also apply a PostScript fill by clicking the Interactive fill tools button
in the toolbox, clicking the Fountain fill tool
