You can have one inch on your screen equal one inch of “real” distance. This lets you work with real-world distances as opposed to relative distances that depend on screen resolution. This tool is particularly useful when you work with signs or draw in 1:1 zoom mode.
Before you can perform this procedure, you must have a clear plastic ruler for comparing real-world and on-screen distances. This ruler should use the same unit of measure that you set for the Corel DESIGNER rulers. For information about ruler settings, see Using the rulers.
| To calibrate the rulers to real-world distance |
1. |
Click Tools |
2. |
In the Workspace list of categories, double-click Toolbox, and click Zoom, Pan
tool.
3. |
Click Calibrate rulers.
4. |
Place a clear plastic ruler under the on-screen horizontal ruler.
5. |
Click the up or down arrows on the Horizontal box to match one unit of measure
on the on-screen ruler with one unit of measure on the actual ruler.
6. |
Place the ruler beside the on-screen vertical ruler.
7. |
Click the up or down arrows on the Vertical box to match one unit of measure on
