If you no longer want table text to appear in a table, you can convert the table text to paragraph text. For more information about converting text to a table, see To create a table from text.
| To convert a table to text |
1. |
Click the Table tool
2. |
Click Table |
3. |
In the Separate cell text with area, choose one of the following options:
Commas — replaces each column with a comma and replaces each row with a
paragraph marker
Tabs — replaces each column with a tab and replaces each row with a paragraph
marker
Paragraphs — replaces each column with a paragraph marker
User defined — replaces each column with a specified character and replaces
each row with a paragraph marker
If you enable the User defined option, you must type a character in the User defined box. |
If you do not type a character in the User defined box, each of the table rows
is converted into a paragraph, and the table columns are ignored.
