Corel DESIGNER lets you draw rectangles and squares. You can draw a rectangle or square by dragging diagonally with the 2-point rectangle tool or by specifying the width and height with the 3-point rectangle tool. The 3-point rectangle tool lets you quickly draw rectangles at an angle.
You can create a 3-point rectangle by first drawing its baseline and then drawing its height. The resulting rectangle is angled.
You can also draw a rectangle or square with rounded, scalloped or chamfered corners. You can modify each corner individually or apply the changes to all corners. In addition, you can specify that all corners scale relative to the object. You can also specify the default corner size for drawing rectangles and squares.
Rounding produces a curved corner, scalloping replaces the corner with an edge that has a curved notch, and chamfering replaces the corner with a straight edge, also known as a bevel.
The cabinet doors have different styles applied to the corners. From left to right you can see standard corners with no changes, filleted corners, scalloped corners, and chamfered corners.
To draw rectangles or squares with rounded, scalloped, or chamfered corners, you need to specify the corner size. For rounding or scalloping a corner, the corner size determines the corner radius. The radius is measured from the curve’s center to its perimeter. Higher corner size values produce more rounded corners or deeper scalloped corners.
From left to right, you can see the radius of a rounded corner and the radius of a scalloped corner.
The size value for chamfering a corner represents the distance from the original corner to the beginning of the chamfered edge. Higher values produce a longer chamfered edge.
For more information about modifying the corners of curve objects, such as lines, text, or bitmaps, see Filleting, scalloping, and chamfering corners of curve objects.
| To draw a rectangle or square by dragging diagonally |
You can draw a rectangle from its center outward by holding down Shift as
you drag. You can also draw a square from its center outward by holding down
Shift + Ctrl as you drag.
| To draw a 3-point rectangle |
1. |
In the toolbox, click the 3-point rectangle tool
2. |
In the drawing window, point to where you want to start the rectangle, drag to
draw the width, and release the mouse button.
3. |
Move the pointer to draw the height, and click.
To adjust the size of the rectangle, type values in the Object size boxes on the Transform toolbar. To open the Transform toolbar, click View |
To constrain the angle of the baseline to a preset increment, known as constrain
angle, hold down Ctrl as you drag. For information about changing the
constrain angle, see To constrain an object while drawing or editing.
| To draw a rectangle or square with rounded, scalloped, or chamfered corners |
1. |
Click a rectangle or square.
2. |
Click one of the following buttons on the property bar:
Round corner
Scalloped corner
Chamfered corner
3. |
Type values in the Corner radius boxes on the property bar.
4. |
Press Enter.
If you modify the corners of a rectangle or square and save it to a previous
version of Corel DESIGNER, the shape may be converted to curves.
You can also modify the corners of a selected rectangle or square by clicking
the Shape tool
| To specify the default corner size for drawing rectangles and squares |
1. |
Click Tools |
2. |
Double-click Toolbox from the Workspace list of categories.
3. |
Click Rectangle tool.
4. |
In the Rectangle corners area, type values in the boxes.
You can also
Apply the same changes to all corners
Click the Edit corners together button
Disable the scaling of corners relative to the object
Click the Relative corner scaling button
