Corel DESIGNER includes controls that let you format text in different languages. You can limit any font, style, and size changes to only Latin, Asian, or Middle Eastern text by choosing the script type. For example, if you want to change the font size of Korean text in a document that includes both English and Korean text, you can choose the Asian script type, and then change the font size. This applies the new font size only to the Korean text, the English text font size is unaffected. You can also enable right-to-left text flow when working with bidirectional languages, such as Middle Eastern languages. In addition, you can mix latin text with Asian or Middle Eastern in one text object and set the spacing between the two words.
| To limit font property changes to multilingual text |
1. |
Using the Text tool
If the Property manager docker is not open, click Window |
2. |
In the Property manager docker, click the Character button
3. |
In the Character area of the Property manager docker, choose one of the
following language options from the Language group and script list box:
All languages
Latin
Asian
Middle Eastern
4. |
Change any font properties.
The Language group and script list box is available only when using an Asian
or Middle Eastern operating system or when language support is installed on
the operating system.
| To set right-to-left text flow in a text frame |
1. |
Do one of this following:
Using the Text tool
Using the Pick tool
2. |
In the Property manager docker, click the Paragraph button
3. |
In the Paragraph area of the Property manager docker, choose an option from
the Text direction list box.
The Text direction option is available, and visible, only when you use a Middle
Eastern operating system or when language support is installed on a non-
Middle Eastern operating system.
You can also change the direction of text flow in columns. For more
information, see To change the flow of bidirectional text in columns.
| To specify spacing between Latin and Asian words |
1. |
Using the Text tool
2. |
3. |
In the Paragraph area of the Property manager docker, type values in the
Language spacing box.
The language spacing value is based on the percentage of a standard space. For
example, two spaces are represented by typing a value of 200.
