Supported file formats
A file format defines how an application stores information in a file. If you want to use a file created in a different application than the one you are currently using, you must import that file. Conversely, if you create a file in one application and want to use it in another application, you must export the file to a different file format.
When you name a file, an application automatically appends a filename extension, usually three characters in length (for example, .cdr, .bmp, .tif, and .eps). This filename extension helps you and the computer differentiate between files of different formats.
The following list includes all file formats used in this application. Note that not all file format filters are installed by default. If you cannot export or import a file from the list, you need to update your installation of CorelDRAW Graphics Suite. For more information, see Modify and repair installations.
Adobe Illustrator (AI)
Windows Bitmap (BMP)
OS/2 Bitmap (BMP)
Computer Graphics Metafile (CGM)
CorelDRAW (CDR)
Corel Presentation Exchange (CMX)
Corel PHOTO-PAINT (CPT)
Cursor Resource (CUR)
AutoCAD Drawing Database (DWG) and AutoCAD Drawing Interchange Format (DXF)
Encapsulated PostScript (EPS)
PostScript (PS or PRN)
GIF
High Efficiency Image File Format (HEIF)
JPEG (JPG)
JPEG 2000 (JP2)
Kodak Photo CD Image (PCD)
PICT (PCT)
PaintBrush (PCX)
HPGL Plotter File (PLT)
Portable Network Graphics (PNG)
Adobe Photoshop (PSD)
Corel Painter (RIF)
TARGA (TGA)
TIFF
WordPerfect Graphic (WPG)
RAW camera file formats
Wavelet Compressed Bitmap (WI)
Additional file formats
Recommended formats for importing graphics
Recommended formats for exporting graphics
