After you create a lens, you can edit it. For example, you can add areas to it and remove areas from it. You can change the lens properties or change the transparency of a lens to fine-tune the changes you want to apply to the image.
Lenses can be selected and transformed in the same way that you select and transform objects. For information about selecting and transforming objects, see Working with objects and Modifying objects. You can also change the shape of a lens using a special effects filter. For more information about special effects, see Applying special effects.
| To add an area to a lens |
1 |
Click the Object pick tool |
2 |
Select a lens.
3 |
Click one of the following:
Paint tool |
Rectangle tool |
Ellipse tool |
Polygon tool |
Line tool |
4 |
On the property bar, specify the tool’s attributes.
Ensure the New object button |
5 |
Drag across the areas that you want to add to the lens.
When adding areas to a lens, the grayscale value of the foreground color or fill
color affects the lens opacity. White adds areas to the lens, while black makes
lens areas transparent. For more information, see Working with object
transparency.
The Rectangle tool, Ellipse tool, Polygon tool, and Line tool create new
objects by default.
| To remove an area from a lens |
1 |
2 |
Select a lens.
3 |
Click the Eraser tool |
4 |
On the property bar, specify the Eraser tool’s attributes.
5 |
Drag across the areas that you want to remove from the lens.
| To change the properties of a lens |
1 |
2 |
Select a lens.
3 |
Click Object |
4 |
Edit the lens properties.
You cannot change the properties of a Desaturate lens or an Invert lens.
| To change the transparency of a lens |
1 |
2 |
Select a lens.
3 |
In the Objects docker, type a value in the Opacity box.
If the Objects docker is not open, click Window |
The Opacity box is not available for 1-bit black-and-white images.
| To change the shape of a lens by using a special effects filter |
1 |
2 |
Select a lens.
3 |
Click Effects, and click a special effect.
4 |
Specify the settings of the special effects filter.
Only some special effects change the shape of lenses. For example, many special
effects from the 3D and Distort special effect categories work well.
