JPEG is a standard format developed by the Joint Photographic Experts Group. Through the use of superior compression techniques, this format allows the transfer of files among a wide variety of platforms. JPEG supports 8-bit grayscale, 24-bit RGB, and 32-bit CMYK color modes.
The JPEG format is commonly used on the Web. For more information, see Choosing a Web-compatible file format.
| To import a JPEG file |
1. |
Click File |
The File |
2. |
Locate the folder in which the file is stored.
3. |
Do one of the following:
(Windows 7 and Windows Vista) Choose JPG - JPEG Bitmaps (*.jpg; *.jtf;
*.jff; *.jpeg) from the list box next to the File name box.
(Windows XP) Choose JPG - JPEG Bitmaps from the Files of type list box.
4. |
Click the filename.
5. |
Click Import.
6. |
Click the image window.
You can also
Resample a graphic while importing
For more information, see To resample an image while importing.
Crop a graphic while importing
For more information, see To crop an image while importing.
You can drag on the image window to resize the image.
| JPEG technical notes |
JPEG files can contain EXIF data. This data may affect how the JPEG files open.
