The Tagged Image File format (TIFF) is a raster format designed as a standard. Almost every graphics application can read and write TIFF files. TIFF supports various color modes and bit depths.
You can open or import TIFF files in Corel PHOTO-PAINT. For more information about opening or importing files, see Opening images or Importing files.
| To export a TIFF file |
1. |
Click File |
2. |
Locate the folder in which you want to save the file.
3. |
Choose TIF - TIFF bitmap from the Save as type list box.
4. |
Type a filename in the File name list box.
5. |
Click Export.
| TIFF technical notes |
When importing a TIFF that contains multiple pages, you can choose the
individual pages that you want to import.
Masks are not exported in 1-bit black-and-white, 16-bit grayscale, or 48-bit RGB
files.
Black-and-white, color, and grayscale TIFF files up to and including the 6.0
specification can be imported and exported.
TIFF files compressed using JPEG, ZIP, CCITT, Packbits 32773, or LZW
compression can also be imported. However, you may notice additional loading
time with these files because the program decodes the file compression.
