Templates help you simplify image placement and sizing. You can use templates to lay out and print images in standard sizes, including 4 × 6 inches, 5 × 7 inches, and 10 × 15 centimeters. You can use a Corel PaintShop Pro template, or you can create your own custom template from a page layout that you create.
Creating your own layouts gives you the flexibility to print images to any size and lets you create a custom page for projects such as scrapbooks. For more information about creating layouts, see Creating layouts.
| To print the active image |
| 1 | Choose File |
| 2 | In the Printer group box, click Printer. |
| The Print dialog box appears. |
| 3 | Choose a printer from the Name drop-list, and click OK. |
| 4 | Click the Placement tab, and type or set a value in the Number of copies control. |
| 5 | In the Orientation group box, choose one of the following options: |
| • | Portrait |
| • | Landscape |
| 6 | In the Size and Position group box, set any of the following controls: |
| • | Width and Height — lets you specify width and height values to set the image size |
| • | Scale — lets you resize the image by entering a percentage |
| • | Fit to page — fits the image to the printed page |
| • | Center on page — centers the image on the printed page |
| • | Upper left of page — positions the image in the upper-left corner of the printed page |
| • | Custom offset — lets you enter values in the Left offset and Top offset boxes |
| 7 | Click the Options tab. |
| 8 | In the Print Output group box, choose one of the following options: |
| • | Color |
| • | Greyscale |
| • | CMYK separations |
| If you choose the CMYK separations option, you can print CMYK labels on each color plate or page by marking the CMYK plate labels check box in the Print Marks group box. |
| 9 | Click Print. |
Mark the Image Name check box in the Print Marks group box.
Mark the Negative check box in the Color Options group box.
Mark the Background check box, click the color box, and choose a color from the color palette.
You can script most print options; however, because of variations in printer drivers, not all printer settings are scriptable. For more information about scripting, see Scripting basics.
For more information about printing options, see Creating layouts.
| To print a contact sheet |
| 1 | In the Organizer palette, select the files that you want to print. |
| 2 | On the Organizer toolbar, click the Organizer menu button |
| 3 | Specify the settings you want in the Print Contact Sheet dialog box. |
| 4 | Click Print. |
For more information about printing options, see Understanding printing.
| To print to a file |
| 1 | Choose File |
| 2 | Mark the Print to File check box. |
| 3 | Click Print. |
| 4 | Type a name in the Output File Name box. |
| To print images by using a template |
| 1 | In the Manage or Edit workspace, select thumbnails in the Organizer palette. |
| 2 | Choose File |
| The Print Layout window appears. |
| 3 | Click File |
| The Templates dialog box appears. |
| 4 | In the Category group box, choose a category from the list. |
| Thumbnails of the templates in each category appear in the window on the right. Custom templates that you saved appear under the User Defined category. If the custom template was saved with images, the cells are filled with color. |
| 5 | Select a template, and click OK. |
| 6 | Drag images into the template cells. |
| If you want to fill the template with copies of the same image, click a thumbnail and click the Fill Template with Image button |
| 7 | Click File |
For information about saving templates with links to images, see Setting file locations.
You can remove an image from a template by selecting the image and pressing Delete.
You can also open images by choosing File
Open Image.
| To print crop and registration marks |
| 1 | Choose File |
| 3 | Choose a printer from the Name list box, and click OK. |
| 4 | Click the Options tab. |
| 5 | In the Print Marks group box, mark one or more of the following check boxes: |
| • | Corner Crop Marks — prints crop marks at the corners of the image |
| • | Center Crop Marks — prints crop marks at the center of the image edges |
| • | Registration Marks — prints registration marks at the corners of the image |
