Using textures in photo painting and image compositing
You can use textures in photo painting and creating composite images. For information about using textures as clone sources, see To use a texture as a clone source. After you create or modify a texture, you can embed it as a clone source. For information about working with embedded clone sources, see Working with embedded clone sources. Store your content assets as textures in a texture library and reuse them in your projects.
To embed a texture as a clone source
Back to Top
1 Create or open a document.
2 In the Textures panel (Window Media Panels Textures), select a texture, and click the Embed Texture as Clone Source Image button .
The texture appears in the Clone Source panel (Window Clone Source) as an embedded clone source image.
Transparency in PNG images is maintained.
