Troubleshooting tips
This section provides troubleshooting tips and offers answers to frequently asked questions. If your problem or question is not included in the following list, visit the Corel Knowledge Base.
Installation
• I am trying to install/reinstall Corel Painter but I get a warning that my serial number is invalid. What do I do?
• How do I deploy Corel Painter to my organization’s network?
• How do I repair my Corel Painter installation (Windows)?
• How do I uninstall Corel Painter properly (Windows)?
• How can I get the thumbnails of my Painter files to show in Windows Explorer?
Brushes and tablets
• My brushes stopped working.
• I can no longer find some of my brushes.
• My blending and smearing brushes paint with white or don’t interact with underlying colors.
• My brush doesn’t use the color I chose or doesn’t work as expected.
• Where do I find my previously purchased brushes after reinstalling Corel Painter or installing it on another computer?
• My tablet doesn’t work as expected with Corel Painter. What do I do?
Workspaces, user files, and layouts
• What’s the difference between user files and a workspace?
• What’s the difference between a layout and a workspace?
• I was given a custom workspace, but I can’t use it.
• Some palettes in the workspace I just imported appear cutoff (Windows).
Performance
• Lately Corel Painter has been taking longer to start. Can I do something to shorten its startup time?
• What settings do I use to ensure the optimal performance of Corel Painter?
• I was using Corel Painter without any problems for a while, and now it no longer works as expected. What do I do?
• I know that restoring Corel Painter to its default settings may help with unexpected performance problems, but I don’t want to lose my custom brushes and palettes. How do I keep my custom items?
• I have read that renaming my application data folder (Windows) or application library folder (macOS) may help improve the performance of Corel Painter? How do I rename this folder?
• Corel Painter stops responding on startup (macOS)? What do I do?
Installation
Make sure you have pasted or typed the correct serial number, and that you are using a serial number provided by Corel. It may help to paste your serial number into a basic text editor, such as Notepad (Windows) or TextEdit (macOS). Next, copy the serial number from the text editor, and paste it into the Serial Number box.
If you have uninstalled or reinstalled Corel Painter several times, you may have reached the maximum number of times you can use the serial number to activate the product. Contact Corel Customer Service for help.
If you purchased multiple licenses of Corel Painter, you have the option of deploying the software to your organization’s network. See the Corel Painter 2022 Deployment Guide for information about network installations.
If you suspect that your installation of Corel Painter is corrupt, you may need to repair it. To do this, close all applications, and click Uninstall or change a program on the Windows Control Panel. Double-click the product name on the Uninstall or change a program page. In the Installation wizard, enable the Repair option, and follow the instructions.
Always use the Corel Painter Installation wizard to uninstall Corel Painter. Close all applications, and click Uninstall a program on the Windows Control Panel. Double-click the product name on the Uninstall or change a program page. In the Installation wizard, enable the Remove option and the Remove User Files check box, and follow the instructions.
The Corel Painter installation includes Corel Painter Thumbnail Previewer, which lets you view the contents of Corel Painter (RIFF) files in Windows Explorer by generating thumbnail images. This utility must be uninstalled separately. To do so, double-click Corel Painter Thumbnail Previewer on the Uninstall or change a program page.
• Upgrade to the latest version of Corel Painter. It comes with Corel Painter Thumbnail Previewer, which lets you view the contents of Corel Painter (RIFF) files in Windows Explorer by generating thumbnail images.
• If you change the Corel Painter file association, thumbnails may become unavailable. To fix the issue, you must uninstall Corel Painter together with Corel Painter Thumbnail Previewer, and then reinstall the application.
Brushes and tablets
• Check the Layers palette to make sure that the Preserve Transparency button is disabled.
• Make sure the active layer is visible. If the eye icon next to the layer name in the Layers palette is shut, click the icon to make the layer visible.
• Sometimes the brush marks don’t show because the brush opacity is set to 0. Increase the opacity in the Opacity box on the property bar.
• You may be painting underneath a layer that is hiding your brushstrokes. Check the Layers palette, and make sure you are painting on the layer you want. If there are layers blocking the active layer, hide these layers by clicking the eye icon.
• There may be a small selection in the image, and brushes cannot paint outside selections. Choose the Select menu, and click None (if it is not already grayed out) to remove the selection.
• You may be trying to paint on a white canvas with a brush that uses the Glow technology. Glow brushes don’t leave a mark on white or very light backgrounds. To make sure you are indeed using a glow brush, check if there is an enabled Glow control on the property bar, or if the brush uses the Glow subcategory.
• Click the Reset Tool button on the property bar to restore the brush to its default settings.
• Some composite methods can make the paint appear invisible. For example, if the layer’s composite method is set to Multiply or Gel and you are painting on black, you won’t be able to see your brushstrokes. In general, if you are having difficulty seeing your brushstrokes, try changing the layer’s composite method to Default.
• Blender brushes do not add color; they blend existing colors.
• Make sure to clear all brush filters in the Brush Selector by clicking the Filter Brushes button , and clicking Clear Filters.
• Some brush categories and brush variants may be hidden. To show all hidden brush categories, click the Brush library options button in the Brush Selector, choose Category Display, and choose Show All Categories. To show all hidden brushes, click the Brush library options button in the Brush Selector, choose Variant Display, and choose Show All Variants.
• In the Layers panel, click the Pick Up Underlying Color button to enable it. If the brush still doesn't work as expected on the active layer, choose the canvas in the Layers palette and try painting over existing colors. If it works, consider painting on the canvas - some brushes use methods that don’t work on layers.
• For brushstrokes without white fringes, take advantage of enhanced blending, which is supported by many brushes. Choose Window Brush Control Panels Brush Media Blending, and enable the Enhanced Layer Blending check box (if available for the selected brush).
• In the Colors palette, check if the Additional Color swatch appears selected. If so, click the Main Color swatch so that your brush uses the main color.
• In the Layers panel, check the composite method assigned to the active layer in the Composite Method list box, and make sure it is set to Default, not Gel, Multiply, Overlay, or another method that changes the appearance of the main color when it interacts with underlying colors.
• Make sure that the Hue ring and Saturation/Value triangle in the Color palette do not appear grayed out. If they are, then the Clone Color option is enabled, which means that the brush is using a color or pattern from a clone source. In the Color palette, click the Clone Color control to disable it.
• Sometimes your brush may be customized beyond recognition. In the Brush Selector, click the Brush library options button , and choose Restore Default Variant.
Click Help menu Restore Purchases, and follow the instructions to download and install your previously purchased items. This method can help you restore only brush packs that you purchased from within Corel Painter. For more detailed information, see To restore your purchases.
Start by making sure that your tablet preferences are set properly - Wacom-compatible device (Wintab) or RTS-compatible device (Real-Time Stylus). For more information, see Support for tablets and other devices.
Make sure the tablet and the tablet driver are supported by the operating system, and that you have the latest version of the tablet driver installed. After installing the latest driver, you may find that tablet performance has become worse. In such cases, you may want to go back to the previous version of the driver. Remember to restart your computer each time you install or uninstall device drivers.
Unplug the tablet, and try to connect it to your computer by using another USB port.
User files, workspaces, and layouts
User files are created when you customize content (such as a brush, paper or texture) or reposition a workspace element in Corel Painter. For example, when you change the settings of a brush or add a new item to a library, your new settings are saved to user files.
A workspace lets you create a customized version of Corel Painter to suit your workflow needs. A workspace can include custom brush libraries, paper libraries, texture libraries, nozzles, portfolios, and more. In addition, you can easily create multiple workspaces, each with different libraries and portfolios. You can switch workspaces from the Window Workspace menu. For more information about workspaces, see Creating, importing, exporting, and deleting workspaces.
A layout (also known as "palette arrangement") displays, hides, and positions workspace elements such as palettes and panels to suit a specific workflow. For example, the New to Painter layout displays only the most essential controls together with the Hints panel to help you get started quickly with Corel Painter. You can switch layouts while working in the same workspace by clicking Window Layout.
A layout arranges the elements of a workspace in a specific way; a workspace includes specific content such as brushes, textures, papers, and more.
You can arrange palettes and panels and save the arrangement as a custom layout. For more information, see To save an arrangement of palettes as a workspace layout. When you restore Corel Painter to its default settings, you can choose to keep custom brushes, papers, textures, and other assets, but all your custom layouts will be lost.
Workspace files have a .pws extension. To use a custom workspace that was shared with you, you must import it by choosing Window Workspace Import Workspace.
You can double-click a workspace file to import it on the macOS, but not on Windows. If you double-clicked the workspace file on Windows, and then tried to import it unsuccessfully, you need to download the file again.
The location of palettes is saved with the custom workspace. If the imported custom workspace is too wide, some of its palettes may appear cutoff or be completely hidden. Try decreasing the UI scaling value in Windows, and then move the palettes to the left. Next, set the UI scaling to your preferred value.
Performance
Before closing Corel Painter, make sure to close all panels and palettes that you rarely use.
• Run the Brush Accelerator to optimize your system hardware. For more information, see Using the Brush Accelerator to achieve optimal performance.
• If you have multiple GPUs, you can select which one Painter will use. For more information, see Adjusting GPU settings.
• Set performance options in the Preferences dialog box. For more information, see Performance preferences.
• If you frequently use the hard disk rather than an external hard drive or cloud storage, consider investing in a system that has at least 500GB of disk space with solid state technology (for example, 500GB SSD Drive) to safely store each project.
• For ease of connectivity with your drawing tablet, ensure there are easily accessible USB ports or wireless Bluetooth support on your system. Wacom offers an impressive range of drawing tablets and displays with pressure-sensitive pens that closely mimic the traditional drawing experience.
• (Windows) Optimize the settings of your device, be it a Microsoft Surface Pro laptop, Cintiq Companion, or a desktop computer. Change the power settings of your device from Power Save mode to High performance (Control Panel Hardware and Sound Power Options). You can also disable programs that are running in the background, turn off search indexing, clean the registry, disable visual effects, and more. For detailed information, see https://www.computerworld.com/article/3029168/microsoft-windows/windows-10-quick-tips-8-ways-to-speed-up-your-pc.html.
• Set the rotation of the canvas to 0°, especially when using impasto.
• If you are using impasto but you don’t need to see the impasto effect while painting, choose Canvas Hide Impasto to improve performance.
• Hide the Navigator panel (Window Navigator) if you don’t need it.
• Adjust the following brush settings:
• Move the Boost slider on the Spacing panel (Window Brush Control Panels Brush Shape Spacing) to optimize the performance of brushstrokes. Start with low boost values (under 10%) to significantly increase brush performance. Note that high boost values may produce less accurate brushstrokes.This setting applies only to specific brush dab types, such as Flat and Camel hair.
• Check if the selected brush uses Brush Loading by choosing Window Brush Control Panels Brush Media Blending, and disable it to improve performance. For more information about this control, see Blending controls.
We recommend that you follow these troubleshooting tips in the order they are listed.
• Restart Corel Painter. This may improve application performance.
• Sometimes, silent hardware and operating system (OS) updates may cause Corel Painter to slow down. Its performance should be improved after the updates are installed. In general, we recommend that you restart your computer after installing any hardware, OS, or Corel Painter updates.
• Start Corel Painter by holding down Shift. This action will restore Corel Painter to its default settings and may solve unexpected problems. For more information, see Restoring the default Corel Painter settings.
• If restoring Corel Painter to its default settings did not improve performance, the problem may be some custom items such as brushes, papers, or custom palettes that you created earlier and decided to keep. Start Corel Painter while holding down Shift again, and try disabling one or more items under the Keep some customizations option.
• Another fix to try on Windows is to rename the Corel Painter folder in your User folder. For more information, see I have read that renaming my application data folder (Windows) or application library folder (macOS) may help improve the performance of Corel Painter? How do I rename this folder?.
• If you are still having problems using the application and suspect that the installation has become corrupt, you may need to repair the installation. For more information, see How do I repair my Corel Painter installation (Windows)?.
• If nothing else seems to work, you may need to uninstall and re-install Corel Painter. Before you uninstall the application, make sure you have your Corel Painter serial number handy. For information about how to uninstall Corel Painter on Windows, see How do I uninstall Corel Painter properly (Windows)?.
• When you restore the application to its default settings by holding down Shift and starting it, choose the Keep some customizations option in the dialog box that comes up. You can choose to keep your custom brushes, custom palettes, and customized libraries (papers, patterns, scripts, textures, and more).
• You can also export custom content or custom palettes before restoring Corel Painter to its default settings.
(Windows) Press the Windows key + R, type %appdata% in the Run dialog box, and press Enter. Next, browse to the Corel/Painter [XX] folder, where XX is the version number of the product, and rename the folder to Painter XX_old. Start Corel Painter.
(macOS) Start Finder. Choose Go Go to Folder, type ~/library in the Go to folder box, and click Go. Next, browse to the Corel/Painter [XX] folder, where XX is the version number of the product, and rename the folder to Painter XX_old. Start Corel Painter.
For troubleshooting tips, check out this article on the Corel Knowledge Base.
