Auto-Painting Photos
Even if you have no experience with digital art, the Auto-Painting panel lets you create paintings based on digital images or scanned photos. You simply choose a Smart Stroke Brush variant and let Smart Stroke Painting and Smart Settings do the work. If you want more control over how the brushstrokes interact with the canvas, you can set individual stroke settings. Although the Smart Stroke Brush variants are optimized for auto-painting, you can also use any Cloner brush variant.
Auto-painting applies brushstrokes to the canvas.
Using the Auto-Painting panel
The Auto-Painting panel lets you specify how paint strokes are applied to a photo. You can choose from the following options:
Smart Stroke Painting — automatically applies paint strokes that follow forms in the photo
Smart Settings — changes the size, length, and pressure of brushstrokes in areas of greater detail. This option can be used with Smart Stroke Painting to preserve detail from the source photo.
Stroke — lets you choose a brushstroke. You can also add custom brushstrokes to the list.
Randomness — introduces an “accidental” quality in color and stroke. Randomness contributes to the appealing, unique look of artwork created with Corel Painter. You can control the randomness of the following settings:
Pressure — lets you set a value from 0 to 100 to specify the amount of pressure with which brushstrokes are applied. This setting represents the percentage of the preset pressure for the Stroke option.
Length — lets you set a value from 0 to 100 to specify the length of the brushstrokes. This setting represents the percentage of the preset length for the Stroke option.
Rotation — lets you set a value from 0 to 360 degrees to specify the rotation of the brushstrokes.
Brush Size — lets you set the brush size
You can control the speed of auto-painting so that you can see how and where individual strokes are applied. You can also stop the auto-painting process at any time.
To auto-paint a photo by using Smart Stroke Painting Back to Top
In the document window, select the image that you want to auto-paint.
Choose Window Auto-Painting Panels Auto-painting.
In the Auto-Painting panel, enable the Smart Stroke Painting check box.
If you want the paint strokes to adjust automatically in size, length, and pressure to areas of greater detail, enable the Smart Settings check box.
4
In the Auto-Painting panel, adjust the Speed slider to control the speed at which brushstrokes are applied.
5
Click the Play button .
Brushstrokes are applied automatically. You can view the auto-painting progression more easily when Tracing Paper is turned off. If Tracing Paper is turned on, you can turn it off by pressing Command + T (Mac OS) or Ctrl + T (Windows).
6
Click the Stop button when you are satisfied with the results.
If you do not click the Stop button, auto-painting stops at the end of the brushstroke cycle.
To auto-paint a photo by using Stroke settings Back to Top
In the Auto-Painting panel, choose a stroke from the Stroke list box.
Adjust any of the following settings: Randomness, Pressure, Length, Rotation, or Brush Size.
4
Adjust the Speed slider to control the speed at which brushstrokes are applied.
5
6
You can also
Randomize the brushstrokes
Adjust the Randomness slider. The settings in the slider determine the range of randomness for Pressure, Length, and Rotation. For example, if the Randomness for Pressure slider is set to 32% and you set the Randomness slider to 64%, the pressure for each stroke is between 0% and 32% with a variation of 64%.
Randomize the pressure of the brushstrokes
Click the Randomness for Pressure button, and then adjust the slider.
Randomize the length of the brushstrokes
Click the Randomness for Length button, and then adjust the slider.
Randomize the rotation of the brushstrokes
Click the Randomness for Rotation button, and then adjust the slider.
You can use a custom stroke by clicking the menu arrow beside the Stroke list box and choosing Record Stroke. Paint a stroke on the canvas, and choose Save Stroke from the same menu. Your stroke is added to the Stroke list box. For general information about recording brushstrokes, see Recording and Playing Back Brushstrokes.
