Cloning Controls
The Cloning controls are specific to brushes that use the cloning method and affect other brushes only when the Clone Color option is enabled.
The Clone Color control directs a brush to pick up color from a source image. Clone Color takes averaged samples of color from the clone source, resulting in an approximation of the original. The Clone Color option is also available on the Color panel. For information about using different clone types, see Cloning Color.
The Clone Type control lets you choose between several cloning variations. These variations are arranged according to the number of reference points used. With two or more reference points, you can apply a transformation (rotate, skew, scale mirror, and perspective) during cloning. For complete information on using the different clone types, refer to Image Cloning and Sampling.
The Obey Source Selection option uses any selection in the clone source region to constrain painting in the destination. If a transform Clone Type is used, the selection is appropriately transformed. This option is available only with the Cloning method.
When Copy Source Selection is enabled, the Cloner brush reproduces the source selection information in the destination selection. This option is available only with the Cloning method.
With the 4-Point Tiling option enabled, your clone source is tiled in a repeating pattern.
Normal (0), or zero-point, cloning references the upper-left corners of the source and destination documents and patterns. This means that the pixels of the destination document correspond directly to the pixels of the source document. This type of cloning, in which no transformations occur, is valid only between documents. This type of cloning is the basic type of cloning between documents.
Offset (1) cloning offsets the image from the source. The source and destination areas can be at different locations in the same or different documents. Offset cloning is basic point-to-point cloning and is useful for retouching photographs. For more information, see Performing Offset Sampling.
Rotate & Scale (2) cloning rotates and scales the source image using two reference points.
Rotate & Scale cloning. Note that the source and destination reference points are numbered and connected by a line.
Scale (2) cloning scales the source image using two reference points. The distance between the two destination points, in relation to the distance between the two source points, determines the scaling transformation.
Scale cloning.
Rotate (2) cloning rotates the source image using two reference points. The line between the two destination points in relation to the line between the two source points determines the rotation transformation.
Rotate cloning.
Rotate & Mirror (2) cloning rotates and mirrors (flips) the source image using two reference points.
Rotate & Mirror cloning.
Rotate, Scale, & Shear (3) cloning rotates, scales, and shears (slants) the source image using three reference points. The relative positions of the three source and destination reference points determine the transformation effect.
Rotate, Scale, & Shear cloning.
Bilinear (4) cloning applies a bilinear warp to the source image using four reference points. The relative positions of the four source and destination points describe the bilinear transformation.
Bilinear cloning.
Perspective (4) cloning applies perspective to the source image using four reference points. The relative positions of the four source and destination points describe the perspective transformation.
Perspective cloning.
When you work with brushes using the Cloning method, you can modify the Variability to control the offset of the clone based on the location of the source image. When Variability is set at zero, the pixels of the source and destination images correspond precisely. Using a cover brush at full Opacity (and no Grain) simply re-creates the source image.
Brushstrokes with Variability set to 0 (top) and 12 (bottom)
Introducing a degree of randomness disturbs the pixel-to-pixel correspondence. The resultant variations in the image distance the clone from its photographic source, which can contribute to a Natural-Media appearance.
The How Often controls allow you to set the period between random offsets.
Brushstrokes with How Often set to 0 (top) and 15 (bottom)
Random Clone Source randomly samples the source document and then places strokes on the clone destination. There is no correspondence between the samples taken from the source and where they are placed on the clone. The result is a random pattern of the predominant colors and edges of the source. The brush and stroke determine the nature of the pattern.
You might use Random Clone Source with a faint stipple brush to add “noise” to an image. In this case, the clone source image merely contains the noise colors that you wish to add.
Brushstrokes with Random Clone Source disabled (left) and enabled (right)
To set clone color Back to Top
Choose Window Brush Control Panels Cloning.
Enable the Clone Color check box.
To set clone type Back to Top
Choose a type from the Clone Type list box.
To constrain painting in the destination Back to Top
Enable the Obey Source Selection check box.
To reproduce the source selection information in the destination selection Back to Top
Click the Copy Source Selection check box to enable or disable the option.
To tile clone source Back to Top
Enable the 4-Point Tiling check box.
To set clone location variability Back to Top
Perform a task from the following table.
To
Do the following
Increase the range (distance) that the sample can be offset
Move the Clone Location Variability slider to the right.
Limit offset so that source and destination images correspond more precisely
Move the Clone Location Variability slider to the left.
Clone location sliders have no effect when Clone Color is enabled in the Color panel. They have an effect only when a Clone method is used.
To set the period between random offsets Back to Top
To
Do the following
Offset a greater number of samples and give the clone image a rough, distorted look
In the Clone Location area, move the How Often slider to the left.
Offset samples less frequently and keep the clone image more coherent
In the Clone Location area, move the How Often slider to the right.
To choose the Random Clone Source option Back to Top
Enable the Random Clone Source check box.
