Creating and Deleting Paper Textures
You can create your own paper texture by choosing a pattern and then modifying the spacing of the pattern elements. You can also modify the angle of the pattern elements to alter the direction of the texture.
You can create a paper texture from a selected pattern.
You can also create a paper texture by selecting an area of an image and converting it into a paper texture.
A paper texture was generated by selecting an area of the image (left). An example of applying a brushstroke to the canvas using the new paper texture (right).
To create a paper texture Back to Top
Choose Window Paper Panels Papers.
In the Papers panel, click the Papers Options button , and choose Make Paper.
In the Make Paper dialog box, choose a pattern from the Pattern list box.
4
Adjust the Spacing slider.
Moving the Spacing slider to the right opens up the space between rows and columns in the selected pattern. It also increases the size of the pattern.
5
Adjust the Angle slider.
Moving the Angle slider changes the direction of the texture rows.
6
Type a name in the Save As text box.
The paper texture appears as the last selection in the Papers panel.
Tip
You can also make a paper texture from the Paper Libraries panel by clicking the Make Paper button .
To capture paper texture Back to Top
Open or create an image.
Choose the Rectangular Selection tool from the toolbox.
Drag in the document window to select the area of the image that you want to capture as a paper texture.
4
In the Papers panel, click the Papers Options button , and choose Capture Paper.
If you want to blend the distinction between tile borders, in the Capture Paper dialog box drag the Crossfade slider to the right.
5
The paper texture is added to the currently selected library.
The Make Fractal Pattern feature and certain weaves also produce excellent paper textures. For more information, see Creating Fractal Patterns.
Tip
You can also capture a paper texture from the Paper Libraries panel by clicking the Capture Paper button .
