The Text tool property bar contains basic controls for setting text appearance and flow. You can change the font, size, and position and adjust the spacing between letters or lines. You can also perform these tasks from the Text panel, where you’ll find additional text controls.
You can add text to images and change text properties. You can specify text properties using the property bar or Text panel either before or after you type in the document window. For more information about changing text properties, see Creating and Formatting Text and Applying Effects to Text.
| To add text to an image |
1 |
Choose the Text tool |
2 |
Click anywhere in the document window, and type.
You can adjust many text elements on the property bar when the Text tool is
selected, or in the Text panel.
You can change the font and point size of text by selecting a text layer in the Layers panel and then setting options on the property bar or in the Text panel. You can also fill your text with color from the Colors panel.
| To change the font, point size, and color of text |
1 |
2 |
In the Layers panel, select a text layer.
To display a list of all available fonts, choose Other Fonts from the
Font pop-up menu.
You can also choose a font, point size, and color before you type any text.
You can adjust many text elements in the Text panel, or on the property bar
with the Text tool selected.
A text block can be aligned to the left, right, or center. The text baseline origin is used as the reference point for the text alignment. You can specify alignment in the Text panel.
| To align text |
1 |
2 |
3 |
On the property bar, enable one of the following buttons:
Align Left |
Align Center |
Align Right |
You can also align text by choosing the Layer Adjuster tool |
Kerning refers to adjusting the amount of space between letters. Corel Painter does this automatically with most fonts. However, you can fine-tune the spacing with the Tracking slider.
Leading refers to the amount of space between lines of text. You may want to change the Leading from the default. The default spacing between lines is set at 100%.
| To kern text and adjust leading |
